| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > Did an oil change today for 1st time nightmare |
| Ned Member Since: 25 Jul 2015 Location: London Posts: 100      | Sorry Andy but I can't help but chuckle I did the same years ago 😀😀😀😀 | ||
|  Wed Dec 09 2015 9:03pm |
| Andym418 Member Since: 16 Sep 2015 Location: South Yorkshire Posts: 9      | Yes it made a mess. I've always done my own oil changes and servicing as I like to know which oil etc is in and enjoy it when I get time but never ended up with half the oil on the drive. The Mrs isn't too happy. Plenty of newspaper and rags next time | ||
|  Wed Dec 09 2015 9:09pm |
| Ned Member Since: 25 Jul 2015 Location: London Posts: 100      | Well I forgot to put the sump plug back wounderd why it was taking so much oil nearly got a divorce over it 😀. | ||
|  Wed Dec 09 2015 9:51pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Agree it is a silly design. For years now I have always used a massive storage box to catch the oil and even then put big sheets of cardboard over the whole area. Someone at a dealership told me the second plug is something to do with the turbos (maybe the oil feed system?).
|  Wed Dec 09 2015 10:08pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | For future reference, the oil filter box folds in half, wedges nicely between the sump and chassis, and guides the oil gracefully into the tray underneath   | ||
|  Wed Dec 09 2015 10:27pm |
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003      | D/M now that's just giving our trade secrets away   | ||
|  Thu Dec 10 2015 10:37am |
| Andym418 Member Since: 16 Sep 2015 Location: South Yorkshire Posts: 9      | Cheers Mikey will do that next time.
|  Thu Dec 10 2015 11:35am |
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003      | Change the oil and filter on mine every 5000, use good oil and always drive on light throttle on warm up and let the turbos cool down before turning the engine off (drives the Mrs nuts) sitting there with the engine ticking over but it's cheaper than replacing the turbos. If I ever have problems then it's one of those things but I've done what I could   | ||
|  Thu Dec 10 2015 1:28pm |
 I change the oil in my own car every 10k miles. The modern intervals of 15/16k+ is waaaay to long, even for having fancy long life oil If I were running a TDV8, I'd be doing the oil every 6k miles But the post above is also very wise. I do it with every car I own, petrol and diesel, turbocharged or otherwise   | ||
|  Thu Dec 10 2015 1:44pm |
| chopperneil Member Since: 25 Aug 2015 Location: Kent Posts: 55      | Planning on doing a interim change on mine shortly, have had the oil for a month but no time to do it as yet! as far as doing it on the drive if i lock it in off road height and chock the wheels is that enough space to get under it? I have a couple of axle stands as well that i can put under the chassis just in case!
|  Thu Feb 04 2016 12:59pm |
| chopperneil Member Since: 25 Aug 2015 Location: Kent Posts: 55      | found a thread detailing the procedure with pics!
|  Thu Feb 04 2016 1:15pm |
| chopperneil Member Since: 25 Aug 2015 Location: Kent Posts: 55      | The sunshine got the better of me so popped to the local stealer and got the filter and plugs whilst warming up the motor! put it at off road height and put a old double duvet under the front! oil drained without to much mess, ended up using a more rigid piece of cardboard I had to direct the oil but it worked ok, i need a bigger catch can though! Mine holds around 6 or 7 litres so took no risks and interrupted the flow and drained it a couple of times. new filter and o ring fitted and added 8 litres of oil in, let it run briefly and then checked and added another litre, hard to tell on the dipstick where it is but will check it again after a run tomorrow.
|  Thu Feb 04 2016 4:13pm |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677      |
 DM what's the best oil for a 2012 sdv6 as I'm going to change mine,,I've always used millers oils in the past with high performance engines & changed every 5000 & the oil I've removed as always been as clean as when I put it in..also is it advisable to do a engine oil flush.someone mentioned about 2 sump plugs,has the sdv6 got 2.? Andy. Andy. 21 Ford Ranger Gone but not forgotten Focus RS Red Edition 2015 RRS AB Fuji. 2014 RRS SC Santorini 2016 VW Amarok 2014 RRS AB Fuji 2012 RRS Red Edition Fuji 2015 Nissan Navara 2012 RRS SE Santorini 2008 RRS White 2007 RRS Santorino | ||
|  Thu Feb 04 2016 6:57pm |
| flack Member Since: 24 Feb 2013 Location: Preston Posts: 379  | Getting underneath the car is old hat now to drain the oil, I always use an oil extractor, no mess and easy to dispose of.
|  Thu Feb 04 2016 7:08pm |
| Posting Rules
