Home > Technical > Front park aid inactive, no fault shows on the 'secret' menu
Rb1980
Hi all. I have an intermittent problem with my park aids. Previously the pdc would work or I'd just get one continuous been
With no flashing light .now it's switches between working ok and me getting front park aid inactive message.
I've gone into that secret menu to see if it throws up a fault code etc but it doesn't
Any ideas ? Tks
The car is an 09 RRS
Post #478408 Sun Nov 01 2015 4:52pm
Lost for Words
Welcome. Smile
Forget the hidden menu - it won't show there. Activate the sensors and put your ear to each one (Edit: not forgetting to apply the handbrake of course Exclamation ) - if working, you'll here a clicking sound. If no dead sensors (or perhaps all), it'll most likely be a fault on the loom (unless it's the module) - which, given the intermittent nature, is where my bet goes. Thumbs Up Visiting from DISCO3.CO.UK
Post #478412 Sun Nov 01 2015 5:24pm
Rb1980
Hi there! So will the sensors tick as they should ( well the ones that are working)
Even when the park aid inactive message is displayed?
So you think likely the loom? Where can I get one from?
Don't seem to be any on eBay?
Many thanks..
Post #478421 Sun Nov 01 2015 6:13pm
Lost for Words
The inactive message is a good point actually. I guess you'd need to try and listen to them before they shut off. Failing that, faults codes are triggered for any duff sensors.
If it's the loom, it should be possible to identify the problem section and repair it. Thumbs Up Visiting from DISCO3.CO.UK
Post #478485 Mon Nov 02 2015 9:43am
Rb1980
hi
i listend to them before when i had the continuous tone and they all clicked..
think I'll take the bumpoer off and have a look, do i need to take a head light out to unplug the loom from the car?
without a diagnostic tool , is there a way i can see the fault codes?
Post #478488 Mon Nov 02 2015 9:46am
Lost for Words
Not sure if the RRS headlights make a difference (vs D3), but, yes, I assume the connector is still under the headlight. You need diagnostics to see the codes. Thumbs Up Visiting from DISCO3.CO.UK
Post #478495 Mon Nov 02 2015 10:46am
Rb1980
cools, left or right side light?
Post #478496 Mon Nov 02 2015 10:47am
Lost for Words
Right. Thumbs Up Visiting from DISCO3.CO.UK
Post #478497 Mon Nov 02 2015 10:51am
Rb1980
sorry to be a pain, driver or pass. side? Embarassed
Post #478498 Mon Nov 02 2015 10:52am
Lost for Words
No worries - driver's side. Thumbs Up Visiting from DISCO3.CO.UK
Post #478499 Mon Nov 02 2015 10:54am
Rb1980
Post #478500 Mon Nov 02 2015 10:55am
Rb1980
where can I get a cheap loom?
Post #478502 Mon Nov 02 2015 11:09am
Lost for Words
A breaker, I guess, but I would think it unlikely that the existing loom can't be repaired. Thumbs Up Visiting from DISCO3.CO.UK
Post #478525 Mon Nov 02 2015 3:57pm
Rb1980
yeah im thinking should be a simple enough cut n paste job hopefully..cheers for ya help
Post #478526 Mon Nov 02 2015 3:57pm
Lost for Words
Just make sure it's nice and waterproof (soldered and heat-shrunk etc.) so it doesn't happen again! Thumbs Up Visiting from DISCO3.CO.UK
Post #478527 Mon Nov 02 2015 4:00pm
