Home > General > knocking noise
Alfie
England 2008 Range Rover Sport TDV8 HSE Lux Java Black
knocking noise
read several threads on here about the dreaded knocking noise mostly associated with either anti roll bar bushes worn or possibily lower steering column / uj joints replacing or lower arm replacement etc . my question is this , my 2008 tdv8 with 88,000 miles on the clock just passed its m.o.t last week but i have noticed for some time i have this knocking noise that could i guess be any of the suggested faults , so i wonder how has this passed its m.o.t or is worn anti roll bar bushes acceptable or isit something else ??? confused Confused
Post #477458 Thu Oct 22 2015 9:58pm
codfather
Scotland 2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
I think the steering column UJ is more akin to feeling like you are steering with a 50p piece, ie notchy.
It is more than likely one or more of the wishbone bushes, which only shows when the car is driven over a pothole/bump.there is not much movement when up on the ramps, so usually they are missed on MOTs.
The bushes themselves are expensive, and hard to remove, so most garages tend to talk you into getting the whole wishbone replaced, if you do one, you never know when the other two bushes will fail. I had three wishbones done last year for £750
Dave MY10 TDV6 SE (debadged Wink ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
Gone: a comprehensive list of imprezas and a Merc ML AMG
Post #477475 Thu Oct 22 2015 10:50pm
DrRob
Take it to a good independent dealer for them to look it over....... Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #477493 Fri Oct 23 2015 7:33am
Alex C
2008 Range Rover Sport TDV8 HSE Java Black
Had my steering UJ replaced last week, TDV8 with 85k. Difference is really noticeable, had already done bushes, rollbar and ball joints previously and there was still a 'shake' through the steering in certain positions as you pulled away from low speed, all gone now. Smile TDV8 Java Black, Overfinch 22s
Post #477501 Fri Oct 23 2015 8:36am
PAS
England 2008 Range Rover Sport TDV8 HSE Santorini Black
had my lower steering column done few weks ago,the symptoms i had where when turning at bottom of a hill got a knocking sound ,Sometimes going over uneven road surfaces,,I have done my upper & lower wishbones ,check that you have got the weight's fitted that dampen steering noise,mine is a 58 &didn't have them fitted
Post #477506 Fri Oct 23 2015 9:04am
Alfie
I would say that the symptoms are as codfather described , noise when you go over a pothole / bump , I will ask a local garage to have a look at wishbones etc , could be expensive then !![/quote]
Post #477513 Fri Oct 23 2015 9:46am
Timf
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Hi Alfie, the ARC bushes are not an MOT failure. I tried to get them done on warranty but since they are not an MOT failure issue they didn't cough up Rolling Eyes My guess its them
Post #477514 Fri Oct 23 2015 9:49am
Lost for Words
Front lowers would be my bet if they haven't been done yet. Thumbs Up
Drive along at low speed then tap the brakes, and see if they knock. Wink Visiting from DISCO3.CO.UK
Post #477518 Fri Oct 23 2015 10:19am
foxtrotzulu
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Buckingham Blue
I think you'll find one of these has come loose and is rattling.
Post #477547 Fri Oct 23 2015 3:09pm
jje
I have a 2008 TDV8 purchased a year ago from a JLR dealer in Essex with 48,000 from new (Grange Motors),a week after I got it I heard a knocking sound when travelling over pot holes or rough road surfaces and there are lots around here.I took the vehicle back and front lower wishbone wear was diagnosed,these were replaced under warranty and off I went,next day same problem,back in again and the front ARB bushes were replaced,took it away and same problem but after reading a posting on here regarding updated ARB clamps I asked if they had been replaced,NO was the answer,they were replaced and so far all has been well for 4k miles.
My JLR warranty runs out next month and I have renewed it for peace of mind as we all know these lovely cars are very complicated and can be a money pit,HOPE THIS HELPS
Post #477548 Fri Oct 23 2015 3:21pm
