![]() | Home > In Car Electronics > how to hardwire into fuse box |
Wilson Member Since: 06 Oct 2015 Location: Ipswich Posts: 78 ![]() ![]() ![]() |
Can anyone point me to a guide or give me basic instructions how to add equipment to the fuse box?
I've used piggyback fuses for years, never had one with an issue if designed as used.
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5644 ![]() ![]() |
Take a look here for information http://www.rrsport.co.uk/forum/topic28640.html?highlight=blackvue Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Ok, piggy back it is then |
On an 07 it's Mini |
Cheers Bodsy |
Lefty65 Member Since: 19 Oct 2015 Location: Corby Posts: 3 ![]() ![]() |
Bodsy I'm a newbie so can't pm you,but how much do you charge for Bluetooth upgrade,and a totally different question,if I take the fuse out for the DR can I still use the car safely,ie will it still drive normally many thanks lefty 65 |
Lefty, I'll drop you a message. |
I've got all my bits to have a go at this now, just wondered if anyone can advise a good earth on/near the fuse box?
mnk Member Since: 25 Nov 2013 Location: United Kingdom Posts: 231 ![]() ![]() |
Open the panel which is part of the bonnet release handle. Behind this panel you will see 3/4 bolts to the chassis with black wires - Any bolt should do the trick. |
Thanks MNK, I think I know the ones you mean, but I'm talking about the interior fuse box in this case, apologies wasn't very clear. |
As mentioned above, just means you need to run the neg wire down to it.
Done it and all working fine... Used the silver screws below the glove box!
