Home > Technical > H11 LED Fog light bulb with resistors
Wilson
England 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Just searching for H11 LED canbus Fog Light bulbs and some have resistors attached and some do not... can anybody teach me more and tell me if we need them?
Mines an 2007...
I've done everything else, now doing Fog and Cornering bulbs.
Post #476367 Wed Oct 14 2015 3:22pm
Lost for Words
These are great for the cornering lamps:http://www.hids4u.co.uk/h8-28-led-foglight...power.html No resistors required. Wink
I would advise you not to put LEDs in your fog lamps - you would render them useless as the beam is ruined, causing light to stray upwards and refract of the fog. The higher colour temperature is also not helpful, particularly for poor weather conditions. The same effect happens to the cornering lamps, however, I find it is beneficial in that case, as long as good bulbs (i.e. the above) are used to maintain the intensity in the original beam area. Thumbs Up Visiting from DISCO3.CO.UK
Post #476376 Wed Oct 14 2015 4:52pm
Wilson
Thanks for the link... To be honest I very rarely put my fog lights on unless it is actual thick fog outside! So LED fog light bulbs are really a waste of money for me, it's just my OCD was kicking in and wanting them all matching Laughing
Post #476382 Wed Oct 14 2015 5:29pm
Disco_Mikey
Unless you go for fog lights actually designed as/for LEDs
http://www.ebay.co.uk/itm/like/33167542819...mp;ff13=80
Post #476405 Wed Oct 14 2015 8:33pm
Lost for Words
Actually no, Mike. LEDs can't produce a good fog beam at all (though obviously, those are still a scale better than a retro-fit). They are very popular, of course, but they will cause too much glare to work like a fog lamp should. Good for show though, which is why the majority want them anyway. Thumbs Up Visiting from DISCO3.CO.UK
Post #476432 Thu Oct 15 2015 8:26am
Disco_Mikey
Neither can a halogen bulb. It's all down to the design of the reflector Thumbs Up
Post #476436 Thu Oct 15 2015 8:48am
If the lens and reflector is designed for the LED then there's no reason it should give more glare than a traditional lamp. Getting a good tight beam cut off is the key. Also having the lamp as low as possible is beneficial too. The best fog lights I've used were on my 309GTI. They were right at the bottom of the front valance and cut below fog to give good light up the road. 2012 SDV6 - it's missing a couple of cylinders
Post #476437 Thu Oct 15 2015 8:50am
Lost for Words
It's down to to the fact that a halogen or HID lamp has a small filament/arc from which the light is produced. Reflectors and lenses are important, but the small focal point is needed to begin with. The larger area of the LED from which the light is produced means it's not good for a fog beam, and can't produce a spot beam at all. Thumbs Up Visiting from DISCO3.CO.UK
Post #476441 Thu Oct 15 2015 9:11am
I agree that LEDs are no good as a swap for halogen bulbs for the reason you state. If starting from scratch one could design the reflector and lens to deal with the non-point source. It's more involved, of course, but it is possible. 2012 SDV6 - it's missing a couple of cylinders
Post #476464 Thu Oct 15 2015 12:24pm
Lost for Words
A "passable" fog beam can be created, by facing the LEDs towards the reflectors (so, really, bigger reflectors are needed too), but it's still not as precise as it should be (then when it comes to spot beams, even that isn't enough). Thumbs Up Visiting from DISCO3.CO.UK
Post #476465 Thu Oct 15 2015 12:42pm
You do realise that manufacturers are making LED fog lights, don't you? They're on the market and they have cut off beams etc. in exactly the same way that halogen fog lights do. They are also making LED headlights, indeed Audi have LED headlights on some of their range now.
The laws of optics have been known for hundreds of years, are well understood and relatively simple too - school boy physics really. If one knows the source of the light, and it can be a point source, a linear source or a 2/3D source, one can determine the paths of the light and then design reflectors and lenses to direct that light where one wishes.
The main point is that you can't just change a halogen bulb for an LED bulb in a given light unit and expect it to perform correctly. This is because the light won't be hitting the reflectors and lenses in the correct manner for the beam to be correctly formed.
Oh, and don't forget that an incandescent bulb isn't actually a point source, it's a line source - the filament has a much larger dimension one way than the other. 2012 SDV6 - it's missing a couple of cylinders
Post #476482 Thu Oct 15 2015 4:30pm
Disco_Mikey
I'll post a pic of my fogs this evening
Nice, direct, and defined Thumbs Up
Post #476483 Thu Oct 15 2015 4:50pm
Lost for Words
Yes, I do realise they make them - they do so because nowadays fog lights are used more to look "cool" than in genuine fog, and people don't realise/aren't interested in the differences in beam quality. As I say, the reflector facing ones are acceptable, if not perfect, but others aren't good. I did say that this was on a different level to the effect of a retro-fit (I am being picky). Standard headlight beams are a much less-specific beam so are fine. Thumbs Up
Lenses and reflectors can only apply changes to all light rays any given point; if it hits at different angles from the start, both rays are reflected/refracted in the same manner, and so must remain heading in different directions. Wink
Aside from the beam issue, the 6000k colour temperature at which LEDs produce most light, and spikey spectrum does very little favours in bad weather (or indeed in general). Thumbs Up Visiting from DISCO3.CO.UK
Post #476484 Thu Oct 15 2015 5:04pm
Disco_Mikey
DRL
Fog beam
Post #476540 Fri Oct 16 2015 8:00am
Lost for Words
Thanks for going to the effort, Mike. Thumbs Up
I never doubted that those particular lights would produce a reasonable beam, but I think my initial comments came across a bit strongly which was not as intended (too often the way with online discussion). Wink
I still maintain that LEDs will always be very subtly worse than halogen, and it's very hard to see unless in actual fog, but as above, I'm only being very picky here. The colour is still the other issue though. Thumbs Up Visiting from DISCO3.CO.UK
Post #476550 Fri Oct 16 2015 9:01am
