![]() | Home > Technical > H11 LED Fog light bulb with resistors |
| Wilson Member Since: 06 Oct 2015 Location: Ipswich Posts: 78
Just searching for H11 LED canbus Fog Light bulbs and some have resistors attached and some do not... can anybody teach me more and tell me if we need them?
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477
These are great for the cornering lamps:http://www.hids4u.co.uk/h8-28-led-foglight...power.html No resistors required. |
Thanks for the link... To be honest I very rarely put my fog lights on unless it is actual thick fog outside! So LED fog light bulbs are really a waste of money for me, it's just my OCD was kicking in and wanting them all matching |
Unless you go for fog lights actually designed as/for LEDs
Actually no, Mike. LEDs can't produce a good fog beam at all (though obviously, those are still a scale better than a retro-fit). They are very popular, of course, but they will cause too much glare to work like a fog lamp should. Good for show though, which is why the majority want them anyway. |
Neither can a halogen bulb. It's all down to the design of the reflector |
It's down to to the fact that a halogen or HID lamp has a small filament/arc from which the light is produced. Reflectors and lenses are important, but the small focal point is needed to begin with. The larger area of the LED from which the light is produced means it's not good for a fog beam, and can't produce a spot beam at all. |
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9155
I agree that LEDs are no good as a swap for halogen bulbs for the reason you state. If starting from scratch one could design the reflector and lens to deal with the non-point source. It's more involved, of course, but it is possible. 2012 SDV6 - it's missing a couple of cylinders
A "passable" fog beam can be created, by facing the LEDs towards the reflectors (so, really, bigger reflectors are needed too), but it's still not as precise as it should be (then when it comes to spot beams, even that isn't enough). |
You do realise that manufacturers are making LED fog lights, don't you? They're on the market and they have cut off beams etc. in exactly the same way that halogen fog lights do. They are also making LED headlights, indeed Audi have LED headlights on some of their range now.
I'll post a pic of my fogs this evening
Yes, I do realise they make them - they do so because nowadays fog lights are used more to look "cool" than in genuine fog, and people don't realise/aren't interested in the differences in beam quality. As I say, the reflector facing ones are acceptable, if not perfect, but others aren't good. I did say that this was on a different level to the effect of a retro-fit (I am being picky). Standard headlight beams are a much less-specific beam so are fine. |
DRL
Thanks for going to the effort, Mike. |
