| RRSPORT.CO.UK | ||
|  | Home > Technical > Replace or charge Battery |
| Richchad Member Since: 04 Apr 2006 Location: Oxfordshire Posts: 285    |
 My RRS 2010 HSE TDV6 has had no problems with the battery until today, while parked for about an hour had radio on, went to start and nothing apart from flashing lights and low power warning on screen.
|  Wed Sep 30 2015 4:38pm |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477    | Get it on the charge overnight. No need to disconnect anything, but make sure the negative cable's on the ground point, not the terminal.  | ||
|  Wed Sep 30 2015 4:47pm |
| Richchad Member Since: 04 Apr 2006 Location: Oxfordshire Posts: 285    | Ground point, where is that? Why is it different to terminal?
|  Wed Sep 30 2015 4:51pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | With Winter coming buy new AGM Battery Varta/Bosch G14 £140.00 put on yourself job done and forget about it. Don't worry about Battery Monitoring System just make sure battery is fully charged before you fit it.
|  Wed Sep 30 2015 4:58pm |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477    | There are ground points on the body just in front of the engine bay fusebox. It needs to be used so the Battery Monitoring System will see the charge - using the terminal would bypass this.  | ||
|  Wed Sep 30 2015 5:00pm |
| Richchad Member Since: 04 Apr 2006 Location: Oxfordshire Posts: 285    | @ Lost for Words, will take a look to see if I can find them, thanks.
|  Wed Sep 30 2015 5:13pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Hi
|  Wed Sep 30 2015 5:26pm |
 You need an AGM one like these: https://www.tayna.co.uk/019-AGM-Car-Batteries-G414.html   (PS: Try "D2BOYS" discount code.  ) Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver   | ||
|  Wed Sep 30 2015 6:06pm |
| Richchad Member Since: 04 Apr 2006 Location: Oxfordshire Posts: 285    | Okay, so had it on charge all day today, found the ground points, thanks Lost for Words.
|  Thu Oct 01 2015 5:22pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | No problem Richhad
 Lost for Words Just as a point of interest, if a CETK battery charger were to be hard wired in where would the negative connection need to be made, the negative terminal or one of the earth points? Cheers Col | ||
|  Thu Oct 01 2015 5:49pm |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477    | Essentially any ground point will do as long as it's not the terminal.  | ||
|  Thu Oct 01 2015 6:00pm |
|  Fri Oct 02 2015 2:00pm |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477    | Always negative then positive to disconnect, and reverse to reconnect; the reason for this is that the negative side of the battery is grounded to the bodywork - touch the body and the positive terminal to undo it and...  | ||
|  Fri Oct 02 2015 2:14pm |
| Richchad Member Since: 04 Apr 2006 Location: Oxfordshire Posts: 285    | Thanks Lost for Words, so disconnect Neg first, then Positive, wrap pos lead in cloth as someone on here suggested to prevent it touching any metalwork.
|  Fri Oct 02 2015 2:35pm |
| Posting Rules
