![]() | Home > Maintenance & Modifications > Front/rear diff oil change & transfer box |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477
Yes, exactly the same. |
| Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203
Great, thank you kindly for your reply, |
Mmmmm just phoned Land Rover and they tell me front rear diff takes 2.1 litres and transfer box takes 3 litres, that's not correct is it? |
No. |
Front diff takes 0.6/0.7 litres, and the rear p, from memory is around 1.5 |
Yes, thought they were way of the mark, and it's ok to use same oil in diff and transfer box, So if I get 4 litres diff oil that should be adiquate for all 3.. Sorry for being bit dumb it's just want to make sure as its about 50 mile round trip to Land Rover. |
I used this in all three and haven't noticed any issues: http://www.advancedfactors.co.uk/tyk500010...-311-p.asp Yes, 4 litres needed to cover it. |
Cool |
Not at all; you're most welcome. |
I've been reading about the front diff breather filter causing pressure build up due to the factory filter restricting air flow, so is it recommended to do the filter mod. |
Yep, never a bad thing to do, just chop the old one off and stick one of these on: http://www.advancedfactors.co.uk/lr019450-...5131-p.asp |
Cool, that's ordered. |
| All times are GMT |
