Home > Maintenance & Modifications > Front/rear diff oil change & transfer box
Gilly1
hi, I've been doing some reading about front/rear diff oil change, the best I found is the great link to disco3 with directions and pics, my question is are the oil levels/amounts the same for a RR sport, also what about transfer box oil and amount. Mr. Green
Post #474718 Tue Sep 29 2015 7:01pm
Lost for Words
Yes, exactly the same. Thumbs Up
Transfer Box is fill to spill (1.5l). By the book, LR's own (and expensive) "Special Transfer Box Oil" should be used, but quite a few of us have used the same Castrol Syntrax as in the diffs. Wink Visiting from DISCO3.CO.UK
Post #474719 Tue Sep 29 2015 7:17pm
Gilly1
Great, thank you kindly for your reply, Thumbs Up
Post #474741 Tue Sep 29 2015 9:33pm
Gilly1
Mmmmm just phoned Land Rover and they tell me front rear diff takes 2.1 litres and transfer box takes 3 litres, that's not correct is it?
Post #474788 Wed Sep 30 2015 9:45am
Lost for Words
No. Shocked Visiting from DISCO3.CO.UK
Post #474793 Wed Sep 30 2015 9:47am
Disco_Mikey
Front diff takes 0.6/0.7 litres, and the rear p, from memory is around 1.5
Post #474798 Wed Sep 30 2015 9:49am
Gilly1
Yes, thought they were way of the mark, and it's ok to use same oil in diff and transfer box, So if I get 4 litres diff oil that should be adiquate for all 3.. Sorry for being bit dumb it's just want to make sure as its about 50 mile round trip to Land Rover.
Post #474809 Wed Sep 30 2015 11:00am
Lost for Words
I used this in all three and haven't noticed any issues: http://www.advancedfactors.co.uk/tyk500010...-311-p.asp Yes, 4 litres needed to cover it. Thumbs Up
PS: You may find it usedful to have a syringe/pump to get it in. I use one of these: http://www.advancedfactors.co.uk/vs405-oil...3857-p.asp Wink
Also, take a look at the diff bungs and consider replacing them if they look liable to round off... Thumbs Up Visiting from DISCO3.CO.UK
Post #474815 Wed Sep 30 2015 11:17am
Gilly1
Cool Thumbs Up Thank you yet again,
Post #474827 Wed Sep 30 2015 12:26pm
Lost for Words
Not at all; you're most welcome. Thumbs Up Visiting from DISCO3.CO.UK
Post #474848 Wed Sep 30 2015 4:06pm
Gilly1
I've been reading about the front diff breather filter causing pressure build up due to the factory filter restricting air flow, so is it recommended to do the filter mod.
Post #474961 Thu Oct 01 2015 6:40pm
Lost for Words
Yep, never a bad thing to do, just chop the old one off and stick one of these on: http://www.advancedfactors.co.uk/lr019450-...5131-p.asp Thumbs Up Visiting from DISCO3.CO.UK
Post #474965 Thu Oct 01 2015 6:59pm
Gilly1
Cool, that's ordered. Thumbs Up
Post #474968 Thu Oct 01 2015 7:17pm
