Home > General > Battery swap |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
The new one will need the Battery Monitoring System (BMS) resetting with a diagnostic tool, nothing special required on the old vehicle. Visiting from DISCO3.CO.UK
Mon Sep 28 2015 4:12pm |
Timf Member Since: 27 Feb 2010 Location: East Anglia Posts: 312 |
Blimey thanks Lost for Words. Glad I asked. Its not a JLR garage so I reckon I'll let sleeping dogs lie and take the new car with its present battery |
Mon Sep 28 2015 6:52pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1936 |
I don't want to sound rude but isn't it a bit "tight" to want to swap batteries when trading and changing a car? If I was buying your old car, I would be annoyed to fi d out that it had been swapped. |
Mon Sep 28 2015 10:55pm |
Its not just the £200 odd quid, it's the hassle of a flat battery in the morning that happened to me 2 months ago. The dealer is fine with it as its going to auction |
Tue Sep 29 2015 7:21am |
TBH, I'd just swap them over. When these cas get a few years older, do you think the average halfords will be resetting the car for a new battery? Bodsys Brake Bible
Tue Sep 29 2015 8:02am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
2010 should be AGM -- Glass Mat
Tue Sep 29 2015 9:02am |
Many thanks Bodsy, and SRE for the photo - just looked and my 07 TDV8 battery is exactly that...AGM. I don't want to appear tight, but having given the car new discs, pads, battery and B service 8 weeks ago, the dealer offered back the battery as part of the deal. Thanks again chaps |
Tue Sep 29 2015 10:27am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
What does BMS do and why does a battery swap require a plug in on later cars? Visitor from fullfatrr.com * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * Current: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
Tue Sep 29 2015 4:01pm |
Essentially it estimates the battery state of charge. It's mainly there to allow the use of a stop-start system. It was developed over the MYs, and I understand early versions have had a few issues, causing low battery warnings etc. For a real expert, Robbie is probably the best person to ask on things battery and electrical.
Tue Sep 29 2015 4:35pm |
the_big_1 Member Since: 04 Jul 2014 Location: Warwickshire Posts: 577 |
Hi guys,
Tue Sep 29 2015 4:41pm |
Does it not also help to manage the load on the alternator in cold weather and shut down heavy consumers to save heavy load on the alternator and enhance fuel economy when warming up the engine? I've had lots and lots of BMS system problems in Evoques, especially very rapid battery discharge (like flat in 3 days and nobody can say why) which resulted in the car being trailered to the local dealership and placed under observation for 3 weeks to see what heavy users had been discharging the battery. In Land Rover's technical team's view it the 3rd party tracker system but the monitoring proved that was not the cause. I never did find out what was causing the rapid discharge as a combination new software and changing the battery after several replacements went flat with a AGM battery. Voila no more flat batteries. One thing I miss with all recent Land Rover products is that one socket is not left live with the ignition off, I used to use a small £11 Maplin solar panel trickle charger to keep the battery in good condition (and never ever had a flat battery) and one thing that the boffins at LR did in desperation to keep my car's bettery in good nick was to reenable the socket in the centre consol so I could plug in the solar powered trickle charger. It was suggested that I purchase a Land Rover branded battery conditioner which is quite pricey and requires enabling in the car but the draw back is that my car sits on the drive and the battery conditioner needs to be plugged into a mains socket which means having a cable running across the drive for several feet........... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tue Sep 29 2015 4:47pm |
Yeah lots of things use the data, like you say turning off the alternator when not required or turning it on during braking to give more engine braking etc. |
Tue Sep 29 2015 4:50pm |
What if BMS is not reset when a new battery is fitted? Visitor from fullfatrr.com
Tue Sep 29 2015 9:41pm |
Thanks all, and like Dr Rob, can anyone tell us what happens if BMS isn't reset on the new car? |
Thu Oct 01 2015 2:29pm |
