![]() | Home > Technical > Slow acceleration |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
EGR valves. Sounds like they have both failed. Blank them, and report back |
Rucka01 Member Since: 23 Aug 2015 Location: Newcastle upon tyne Posts: 4 ![]() ![]() ![]() |
Going in garage Thursday to go on computer fella reckons it's th egr valves stuck open. Do you think these can just be cleaned/freed? Many thanks |
No, it's normally that the bearings fail, so cleaning yields nothing. On a EU3 car (05/06MY), they can be blanked without any software modifications, so this is cheap, easy and better for the engine and fuel economy. |
Hi been on computer at garage today both valves have faults on them he cleared them but came back on again. I told him to blank them but he just said I should go to a range rover dealer for repairs as he isn't comfortable working onit. I'm on holiday about 100miles away, do you think it will be ok to drive home to go to my local garage I trust? As I say it drives fine once up to speed just a bit smoke off turbo? Many thanks |
Depends really, only you know how bad it is? The lag can get quite dangerous pulling out of juctions, so be sure to keep it in mind. |
Garage blanked off both valves and the car is driving better than it ever has! Thanks for your advice much appreciated |
