Home > Technical > Slow acceleration
Rucka01
United Kingdom 2006 Range Rover Sport TDV6 S Sumatra Black
Slow acceleration
After towing my caravan 2 hours with no problem got in car next day to find the car very slow to pull away takes about 30 secs before the turbo kicks in and a bit black smoke pumps out once up to speed it runs fine! Any ideas please?
Post #470990 Sun Aug 23 2015 6:36pm
Disco_Mikey
EGR valves. Sounds like they have both failed. Blank them, and report back Thumbs Up
Post #470996 Sun Aug 23 2015 8:09pm
Rucka01
Going in garage Thursday to go on computer fella reckons it's th egr valves stuck open. Do you think these can just be cleaned/freed? Many thanks
Post #471069 Tue Aug 25 2015 11:19am
Lost for Words
No, it's normally that the bearings fail, so cleaning yields nothing. On a EU3 car (05/06MY), they can be blanked without any software modifications, so this is cheap, easy and better for the engine and fuel economy. Thumbs Up Visiting from DISCO3.CO.UK
Post #471071 Tue Aug 25 2015 11:24am
Rucka01
Hi been on computer at garage today both valves have faults on them he cleared them but came back on again. I told him to blank them but he just said I should go to a range rover dealer for repairs as he isn't comfortable working onit. I'm on holiday about 100miles away, do you think it will be ok to drive home to go to my local garage I trust? As I say it drives fine once up to speed just a bit smoke off turbo? Many thanks
Post #471209 Thu Aug 27 2015 6:03pm
Lost for Words
Depends really, only you know how bad it is? The lag can get quite dangerous pulling out of juctions, so be sure to keep it in mind. Thumbs Up
Any decent garage should be capable of blanking the EGRs - there's nothing complex about it; it just requires a little care. There's a full guide here if he wants to take a look: http://www.disco3.co.uk/gallery/albums/use...0SMALL.pdf Wink Visiting from DISCO3.CO.UK
Post #471255 Fri Aug 28 2015 8:21am
Rucka01
Garage blanked off both valves and the car is driving better than it ever has! Thanks for your advice much appreciated
Post #471835 Thu Sep 03 2015 9:28am
