Home > Maintenance & Modifications > Cleaning Foam air filters
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
OK, so had the car serviced and had previously taken out the ITG filter I was using so they didn't bin it or anything. They replaced the old stock one with another. I want to replace that with th ITG one again.
It needs cleaning, I have the instructions, but I don't know where to get my hands on the Silkolene cleaner and re-oil spray. Does anyone know where to get it? Or, any other product I can use?
In case anyone else needs it, here's a link to the cleaning instructions:
http://www.itgairfilters.com/content2.asp?section=cleaning L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #47027 Fri Jul 28 2006 12:43pm
Slimer
I got some from here http://www.racespec.co.uk
Post #47047 Fri Jul 28 2006 1:25pm
JESNL
United Kingdom 2005 Range Rover Sport Supercharged Bonatti Grey
Is your filter really a HMP ? Profilters will last about 60,000 miles without much work in normal road conditions (not in the desert or on a potato farm). The Silkolene products are typically used for the filters in motorcycle trials bikes so you may find them at a specialist motorbike shop.
Post #47064 Fri Jul 28 2006 3:58pm
Slimer
The first ITG I got for my D3 was a Handmade, the one I bought recently (as a spare but ended up installing it anyway) is a Pro which as far as I can tell just needs a good vacuming every now and then and then replacing when it doesn't seem to be doing its job anymore
Post #47071 Fri Jul 28 2006 4:15pm
What good is this filter what can it do for my car ??? RRS TDV6 Gone but still around
Post #47074 Fri Jul 28 2006 4:17pm
RRUK
not sure if the instructions I posted were exactly right for the model but the instructions are the same. I might hoover mine tonight! L319 D4 HSE
1982 Series 3 SWB
Post #47075 Fri Jul 28 2006 4:18pm
PaulB
There isn't a huge difference between a brand new standard filter and an ITG filter. However, the BIG difference is that the ITG filter will maintain its performance for much longer, whereas the standard filter will degrade quite markedly quite quickly in terms of air-flow capability.
Paul
Post #47088 Fri Jul 28 2006 4:33pm
How do you know when you need a new one then ? RRS TDV6 Gone but still around
Post #47089 Fri Jul 28 2006 4:35pm
RRUK
unscrew the air box cover (6 retained screws, front left of engine bay on the petrol versions) and lift out the filter, see what state it's in.
Brand new it has a bright pink edge strip and bright yellow paper elements.
See my thread here on the removal of it:
http://www.rrsport.co.uk/forum/topic421.ht...p;start=15 L319 D4 HSE
1982 Series 3 SWB
Post #47093 Fri Jul 28 2006 4:39pm
I have 2k on my clock Very Happy RRS TDV6 Gone but still around
Post #47095 Fri Jul 28 2006 4:42pm
