![]() | Home > Maintenance & Modifications > Cleaning Foam air filters |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2587 ![]() ![]() ![]() |
OK, so had the car serviced and had previously taken out the ITG filter I was using so they didn't bin it or anything. They replaced the old stock one with another. I want to replace that with th ITG one again.
Slimer Member Since: 26 May 2005 Location: Nanny State Posts: 224 ![]() ![]() |
I got some from here http://www.racespec.co.uk |
The first ITG I got for my D3 was a Handmade, the one I bought recently (as a spare but ended up installing it anyway) is a Pro which as far as I can tell just needs a good vacuming every now and then and then replacing when it doesn't seem to be doing its job anymore |
What good is this filter what can it do for my car ??? RRS TDV6 Gone but still around
not sure if the instructions I posted were exactly right for the model but the instructions are the same. I might hoover mine tonight! L319 D4 HSE
PaulB Member Since: 10 Dec 2005 Location: UK Posts: 546 ![]() ![]() |
There isn't a huge difference between a brand new standard filter and an ITG filter. However, the BIG difference is that the ITG filter will maintain its performance for much longer, whereas the standard filter will degrade quite markedly quite quickly in terms of air-flow capability. Paul |
How do you know when you need a new one then ? RRS TDV6 Gone but still around
unscrew the air box cover (6 retained screws, front left of engine bay on the petrol versions) and lift out the filter, see what state it's in.
I have 2k on my clock |
