![]() | Home > In Car Electronics > Daytime Running Lights DRL - Done |
sterling01 Member Since: 19 Apr 2015 Location: Kilmarnock Posts: 146 ![]() ![]() |
After some tips any guidance from the members on here, I got the DRL's done at the weekend.
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 ![]() ![]() ![]() |
they look very nice mate, can i ask what ones you used ? |
14cm, black frame http://www.ebay.co.uk/itm/251626958854 Current - 2020 Range Rover Sport P400e
Thanks may purchase some myself they look great mate |
michaelsanderson Member Since: 14 Dec 2014 Location: West Yorkshire Posts: 32 ![]() ![]() ![]() |
I'd also be interested to see a close up pic - been looking for something like this for a while but worried it's goingt o look very after market. |
I will try over the weekend. When they are off they have a yellow colour to them. As they are so bright, I would consider a thin coat of black paint over them. The type of paint people sometimes use to smoke their rear light clusters. Current - 2020 Range Rover Sport P400e
cubbyno9 Member Since: 22 Oct 2010 Location: Stepps Posts: 149 ![]() ![]() ![]() |
Hi, what length did you get, 14 or 17cms? just what I have been looking for, easy enough to fit ? ta 2017 Range Rover Sport HSE |
Sorry just seen the comment "14cm, black frame". 2017 Range Rover Sport HSE |
kungfupanda79 Member Since: 19 Oct 2011 Location: Manchester Posts: 72 ![]() ![]() |
Have you wired them so they're on all the time when the engine is on? |
They are wired to come on when the ignition is switched on. They stay on till I take the key out Current - 2020 Range Rover Sport P400e
Sounds good. I'm thinking of having the integrated fairy lights inside the headlight. I presume the wiring for them to stay on all the time would be a tad more difficult. |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Hi,look great |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
The wiring is the same, in the sense that you have to run the wires from the headlight to an ignition live, except for the fact that you have to decide how you're gonna deal with splitting the wire once it leaves the headlight. if you don't create some sort of quick release connection, then you can't take the headlight off. what I did was wire the angeleyes through the existing wiring loom quick release connection. was more work, but more professional. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project. DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights. TO DO: color code sills and pillars. |
this has been covered quite a few times recently. best to do a search for "ignition live" and you'll see that the common solution is within the fuse box under the bonnet. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project. DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights. TO DO: color code sills and pillars. |
