Home > In Car Electronics > Daytime Running Lights DRL - Done
sterling01
Scotland
After some tips any guidance from the members on here, I got the DRL's done at the weekend.
 Current - 2020 Range Rover Sport P400e
Gone - 2014 Range Rover Sport HSE SDV6
Gone - 2017 Audi A8 Sport
Gone - 2007 Range Rover Sport HSE TDV8 - Great car.
Post #467716 Thu Jul 16 2015 8:06pm
Wayneclarke
they look very nice mate, can i ask what ones you used ?
Post #467734 Thu Jul 16 2015 9:28pm
sterling01
Scotland
14cm, black frame http://www.ebay.co.uk/itm/251626958854 Current - 2020 Range Rover Sport P400e
Post #467739 Thu Jul 16 2015 9:37pm
Wayneclarke
Thanks may purchase some myself they look great mate
Post #467740 Thu Jul 16 2015 9:40pm
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
Hey looks good Thumbs Up
Do you have any close up photos? Would love to see them, would consider using them also.
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #467773 Fri Jul 17 2015 8:49am
michaelsanderson
England 2011 Range Rover Sport SDV6 HSE Fuji White
I'd also be interested to see a close up pic - been looking for something like this for a while but worried it's goingt o look very after market.
Post #467784 Fri Jul 17 2015 10:16am
sterling01
Scotland
I will try over the weekend. When they are off they have a yellow colour to them. As they are so bright, I would consider a thin coat of black paint over them. The type of paint people sometimes use to smoke their rear light clusters. Current - 2020 Range Rover Sport P400e
Post #467791 Fri Jul 17 2015 10:47am
cubbyno9
Hi, what length did you get, 14 or 17cms? just what I have been looking for, easy enough to fit ? ta 2017 Range Rover Sport HSE
Post #468414 Fri Jul 24 2015 12:05pm
cubbyno9
Sorry just seen the comment "14cm, black frame". 2017 Range Rover Sport HSE
Post #468415 Fri Jul 24 2015 12:11pm
kungfupanda79
Have you wired them so they're on all the time when the engine is on?
Post #469741 Thu Aug 06 2015 11:35pm
sterling01
Scotland
They are wired to come on when the ignition is switched on. They stay on till I take the key out Current - 2020 Range Rover Sport P400e
Post #469746 Fri Aug 07 2015 7:06am
kungfupanda79
Sounds good. I'm thinking of having the integrated fairy lights inside the headlight. I presume the wiring for them to stay on all the time would be a tad more difficult.
Post #469796 Fri Aug 07 2015 5:22pm
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Hi,look great Thumbs Up , Ok i'll ask the obvious, which wire or where did you get the live from to do this ?? Bow down 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #469798 Fri Aug 07 2015 5:40pm
tanloverluke
The wiring is the same, in the sense that you have to run the wires from the headlight to an ignition live, except for the fact that you have to decide how you're gonna deal with splitting the wire once it leaves the headlight. if you don't create some sort of quick release connection, then you can't take the headlight off. what I did was wire the angeleyes through the existing wiring loom quick release connection. was more work, but more professional. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #469803 Fri Aug 07 2015 7:30pm
tanloverluke
this has been covered quite a few times recently. best to do a search for "ignition live" and you'll see that the common solution is within the fuse box under the bonnet. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #469804 Fri Aug 07 2015 7:31pm
