Home > Maintenance & Modifications > Heavy black smoke when Turbo cuts in - split pipe?
Ptang
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Hi all,
Back with yet another problem Smile Under heavy load, flooring accelerator, going up hill etc I get the ubiquitous cloud of black smoke - I've checked the codes and there's no warnings for EGR or Turbo and no engine warning light. If I play with the gears to accelerate smoothly then it's all clear - makes me think it's when the Turbo cuts in.
When having a check of the engine there does seem to be some oily seepage on the front left of the block so I'm inclined to think I have a split pipe BUT I'm not 100% sure which pipes I should be checking - is there an idiots guide somewhere or a couple of pics as to which pipes I should be looking at?
I was going to take the easy way out and get the local stealer to check it but they aren't taking vehicles for a couple of weeks and we're off to France in under 14 days (if the tunnel is not blocked with migrants that is).
And no, I haven't got around to blanking the EGRs yet Smile
Can anyone point me at the pipes to check?
Thanks!
'tang.
Post #468699 Mon Jul 27 2015 11:59am
GrahamS
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
I had clouds of black smoke and it was indeed due to a split intercooler pipe (the one on top of the 2.7 V6).
Post #469236 Sun Aug 02 2015 4:26pm
Ptang
Thanks GrahamS...
Yup - that lines up with the crud that's sprayed out in that area - pipe seems a tad flexible so I'd say it might be shot inside too.
Did you do the replacement yourself? Seems fairly simple - access to top is simple jubilee clip and just a panel to remove under the intercooler to get to the other end?
As I'm pushed for time I may just replace that side now and the other side after my trip to France. Did you use a PNH500025?
Now where the hell did I put the Swarfega?
'tang.
Post #469261 Sun Aug 02 2015 7:57pm
GrahamS
I didn't actually do it myself as I had the car in for new front wishbones too.
Post #469268 Sun Aug 02 2015 8:41pm
GrahamS
I'll try to dig out the invoice for the p/n.
Post #469269 Sun Aug 02 2015 8:43pm
Lost for Words
Ptang wrote:
Thanks GrahamS...
'tang.
Yes, that's the correct PN for the main hose, but I'd suggest you buy a set of silicone ones. Thumbs Up
Easy as pie to replace the main hose. 2 jubilee clips and 4 plastic rivets. The left-hand, large one is not too bad, the little one is a PITA. The main one is the most common failure, though the others have been known to fail. Wink
I'd also suggest you get on and blank your EGRs - Easy enough to do and no software changes required. Guide: http://www.disco3.co.uk/gallery/albums/use...0SMALL.pdf Thumbs Up
For future referrence, you don't even have one. Wink Visiting from DISCO3.CO.UK
Post #469285 Mon Aug 03 2015 8:05am
Ptang
Thanks for all the advice.
Took the easiest path as I needed to get the car sorted before heading to France so got a genuine LR part for the main hose from the nearest dealer for a bargain.
Yup, massive split on underside that just couldn't be seen. 30 minutes and all done. No longer am I a Panzer on retreat from Moscow going up hill. Very Happy
However, after removing the centre from one of the rivets, the other half of the rivet disintegrated on me. Shocked I think I replace the whole set but I'm not having much luck tracking down the p/n for those - any ideas?
Heard lots of good things about the silicone pipes so I think I'll change them next summer when I have more time - not looking forward to the two smaller pipes though! Probably do the EGR blanking at the same time. Whistle
'tang.
Post #469473 Tue Aug 04 2015 8:04pm
Disco_Mikey
Rivets should be ANR2224 Thumbs Up
Post #469483 Tue Aug 04 2015 8:42pm
Ptang
Perfect - thanks DM.
Post #469638 Wed Aug 05 2015 9:01pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
When this happened to me I replaced all the hoses (except the small one) with silicone ones, and had the EGRs blanked, but the problem was a split in the outer casing of the inter cooler.
Post #469822 Fri Aug 07 2015 10:44pm
