![]() | Home > General > Help Stuck in France |
I guess you didnt have a Multimeter with you (not the usual thing to pack in your holiday bag).
| nigel52 Member Since: 20 Nov 2013 Location: Farnham Posts: 274
Hi Bodsy the truck was a small truck with 12 volts. Actually I do have in the car a cigarette lighter fitment that is a digital voltmeter. Forgot to use it but the most it would have told me was the battery volts not whether the alternator was working as I could not start the car.
So the volts would help to indicate if its just a bit of a flat battery (10 volts maybe) or if it's a trollied alternator that has taken the battery with it (Much less volts if any at all).
Bodsey I will go and check the volts and take a battery charger with me and leave it on charge all night. Must decide what to do as car being picked up by breakdown truck tomorrow at 08.30. Any more suggestions before I leave to visit the car? |
Central locking not working had to use emergency key. |
Have you taken the battery off to charge? If the Alternator is fubared, it will just drag it completely down.
Just checked battery voltage at the battery terminals 12.39 volts plug in battery indicator that plugs into cigarette lighter not registering at all. All electric windows works intermittently ,horn, electric seats but not memory function, clock. No lights or interior lights, n central locking or boot. Put on battery charger which over 30 minutes took battery voltage to 13.31 volts but no difference to what worked. Have now left on trickle charge overnight but do not expect it to make any difference.
L R garage were reluctant to tell me how to get it out of drive for the recovery truck to winch it onboard. They said the recovery people will know how to disengage drive. One wonders how one would tow a car like this? |
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003
On P38's you fit a spare fuse in the drivers seat fuse box which makes the transfer box go into neutral, I think you do a similar thing on the RRS/D3 it tells you what to do in the owners manual. 2008 G4 RRSport TDV8 current
with that voltage it should start.
If it's an earth issue as Bodsey's suggests try a jump lead from battery earth to the engine, then see if it starts 2008 G4 RRSport TDV8 current
Engine has never been jetwashed. Body jetwashed about a month ago but very carefully just to get the worst dirt off before handwashing. Battery terminals are tight. New battery in Feb this year. Looks like have to trust the LR garage here in La Rochelle and see what they say. |
Thanks will read the manual again as must have missed this. |
Just remembered another possibility had this on a D3, ignition lights etc but would not start it was a manual so we could tow it off, engine ran but had a boot load of lights on. The fault turned out to be a large fuse at the battery terminal, in the black box at the positive post. Fuse would blow int was a short in the starter motor. 2008 G4 RRSport TDV8 current
| All times are GMT |
