Home > General > Drivers door lock replacement? |
itsmeagain Member Since: 01 Nov 2012 Location: Birmingham Posts: 222 |
I currently have the same issue, driving me crazy. Cars booked in tommorow morning at a local indie, hopefully they will be able to sort it Current 2010 Range Rover Sport HSE with the usual toys: timed climate, Rosen headrest screens, tow bar with twin electrics, Blackvue HD cam
Thu May 28 2015 12:09pm |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
Hello.
Thu May 28 2015 12:19pm |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
Yeah it doesn't look too difficult, but i do have large arms and hands..lol |
Thu May 28 2015 1:48pm |
Si-W85 Member Since: 22 Mar 2015 Location: Huddersfield Posts: 109 |
I too have the same issue on front and rear near side, can anybody share the cheapest place to buy from as the only ones I can find are around £100 each mark? Thanks |
Fri May 29 2015 9:37am |
£100 is what they cost from dealers, I wouldn't entertain getting second hand unit as this seems to be a rather common fault. There's a guy on here selling a new one http://www.rrsport.co.uk/forum/post463253.html#463253. |
Sat May 30 2015 10:49am |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 |
mine is booked in for the same fault, my indie has quoted me nearly £200, thats for the lock, 2 hours labour and vat 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater ))) |
Sat May 30 2015 11:04am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4339 |
They used to be £40 a piece. As ever, with LR, once they start selling a few of them, the prices go up and up
Sat May 30 2015 11:05am |
Ok well I got my door lock changed this morning, took me 1.5hrs and the only tools used were 10mm socket and ratchet, screw driver with 2 torn bits small flat and Philips bit.
Sat May 30 2015 11:08am |
I take the window off the regulator, and tape it over the door frame, to stop it dropping down
Sat May 30 2015 11:11am |
rrsrad Member Since: 05 Feb 2015 Location: Cheshire Posts: 36 |
Blimey thats a good price my indy charged me £330 for the latch and 2 hours labour
Sat May 30 2015 11:15am |
Yes I done that, it's just everyone was saying to undo the window to be able to gain access to the white clips and then as quoted "Before starting lower the window by approx 5" (not strictly necessary but helps). I didn't bother disconnecting the battery and encountered no error codes. Now the fiddly bits begin. The door glass is held to the regulator in two places on the guides. The guides are fairly chunky bits of plastic. To release the glass you simply prise open, by pulling the top edge of the guides towards the outer skin (action shown in red on following picture) while you 'lift' the glass from its guide. To get to the rear most guide you need to get your whole arm into the cavity behind the regulator. What I'm saying is there's no need for this if you just push the window mechanism into the door, it gives ample access. Last edited by Danv8 on Sat May 30 2015 11:19am. Edited 1 time in total |
Sat May 30 2015 11:16am |
Mine seems honest enough, as other peoples prices seem ok, the lock is betweem £98 and £110 depending on dealer, my indie charges £35 an hour labour, though this is now £40 for new customers, so around £200 semms a fair price 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater ))) |
Sat May 30 2015 11:18am |
triplemmm Member Since: 22 Mar 2014 Location: SE Posts: 77 |
I'm getting mine done under warranty. My garage is charging about £100 for the new latch and about £50 for the labour. seems fair |
Sun May 31 2015 6:27pm |
Colin Member Since: 16 Aug 2016 Location: Portsmouth Posts: 5 |
Hi everyone I am new to this but I also had a problem with the drivers door not locking, booked it into the garage and was told the door lock mechanism needed replacing, after ordering a new one online which is due tomorrow for the price of £70.00 I decided to do some research and someone placed a post that said it could be a loose connection under the drivers seat could be the problem. So I decided to have a look myself and I fiddled about with the wiring ( don't know which wire ) but this has rectified the fault. Don't know if this is any use to anyone but it's worth a shot it worked for me.
Tue Aug 23 2016 8:38am |
