Home > General > Door lock
itsmeagain
Door lock
Today i noticed that my car wasnt locking properly on the initial attempt. eventually it did lock from the button on the handle. Is there any other way of locking the car, when it plays up. Just spent the last 2hrs trying to lock the car. Does this sound like i need to change the lock if so which one should i change? Current 2010 Range Rover Sport HSE with the usual toys: timed climate, Rosen headrest screens, tow bar with twin electrics, Blackvue HD cam
2008 Seat Leon K1
2012 Audi A1 2.0litre Black Edition TDI
2004 Audi A4 convertible
2004 Audi A2 TDI
Post #462837 Mon May 25 2015 2:07am
Camelrock
Do you mean 1 door is playing up or all the doors ? If just the 1 then that lock needs changing as the actuator is weak, the lock/actuator is one piece. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #462843 Mon May 25 2015 7:47am
Just had this happen to me - the driver's door in my case. New lock fitted to solve the problem; thankfully, in this case, it's not a big bill item.
You can lock the door using the inside handle, then holding the outside handle open slam the door. This worked for my MY08.
Alternatively reach across the from the passenger's side and flip the lock from the inside and then lock the rest of the car using the key plip.
Obviously make sure you have your keys in your pocket before you try! 2012 SDV6 - it's missing a couple of cylinders
Post #462850 Mon May 25 2015 8:56am
itsmeagain
If i press the button on any of the handles it sounds like its locked, but the second press does nothing then it beeps at me.
If i use the fob i get the same thing happen, and no mirrors fold in
I get the following codes come up with the Diagnostic tool,
DDM-Driver Door
B110A-11 (2F) Rear door driver side central locking motor - General electrical failure - circuit short to ground Current 2010 Range Rover Sport HSE with the usual toys: timed climate, Rosen headrest screens, tow bar with twin electrics, Blackvue HD cam
2008 Seat Leon K1
2004 Audi A2 TDI
Post #462877 Mon May 25 2015 12:49pm
itsmeagain
Is the the central locking motor a different part to the door latch/lock???? Current 2010 Range Rover Sport HSE with the usual toys: timed climate, Rosen headrest screens, tow bar with twin electrics, Blackvue HD cam
2008 Seat Leon K1
2004 Audi A2 TDI
Post #463056 Wed May 27 2015 9:55pm
Paddi
Pretty sure they are the same thing. I did my driver's door latch and there are two motors in it and no sign of any others Thumbs Up 2008 MY Java Black TDV8 HSE
Post #463112 Thu May 28 2015 5:41pm
rrsrad
Had the same fault a couple a months ago on the drivers door, new latch unit (genuine) fitted and two hour labour charge, £330 by my local indy. All working fine now Thumbs Up Range Rover Sport 2010 3.6TDV8 HSE Santorini Black
Post #463130 Thu May 28 2015 8:14pm
itsmeagain
£109 for the rear latch from my rip off local dealer, hopefully the indie will be able to do it tomoz Current 2010 Range Rover Sport HSE with the usual toys: timed climate, Rosen headrest screens, tow bar with twin electrics, Blackvue HD cam
2008 Seat Leon K1
2004 Audi A2 TDI
Post #463134 Thu May 28 2015 8:44pm
