![]() | Home > General > Door lock |
Do you mean 1 door is playing up or all the doors ? If just the 1 then that lock needs changing as the actuator is weak, the lock/actuator is one piece. 2008 G4 RRSport TDV8 current
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9114 ![]() ![]() ![]() |
Just had this happen to me - the driver's door in my case. New lock fitted to solve the problem; thankfully, in this case, it's not a big bill item.
itsmeagain Member Since: 01 Nov 2012 Location: Birmingham Posts: 222 ![]() ![]() ![]() |
If i press the button on any of the handles it sounds like its locked, but the second press does nothing then it beeps at me. If i use the fob i get the same thing happen, and no mirrors fold in I get the following codes come up with the Diagnostic tool, DDM-Driver Door B110A-11 (2F) Rear door driver side central locking motor - General electrical failure - circuit short to ground Current 2010 Range Rover Sport HSE with the usual toys: timed climate, Rosen headrest screens, tow bar with twin electrics, Blackvue HD cam 2008 Seat Leon K1 2012 Audi A1 2.0litre Black Edition TDI 2004 Audi A4 convertible 2004 Audi A2 TDI |
Is the the central locking motor a different part to the door latch/lock???? Current 2010 Range Rover Sport HSE with the usual toys: timed climate, Rosen headrest screens, tow bar with twin electrics, Blackvue HD cam
Pretty sure they are the same thing. I did my driver's door latch and there are two motors in it and no sign of any others |
rrsrad Member Since: 05 Feb 2015 Location: Cheshire Posts: 36 ![]() ![]() ![]() |
Had the same fault a couple a months ago on the drivers door, new latch unit (genuine) fitted and two hour labour charge, £330 by my local indy. All working fine now |
£109 for the rear latch from my rip off local dealer, hopefully the indie will be able to do it tomoz Current 2010 Range Rover Sport HSE with the usual toys: timed climate, Rosen headrest screens, tow bar with twin electrics, Blackvue HD cam
