![]() | Home > Maintenance & Modifications > Parking Sensors not working? |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9158
First port of call is the fuses. Check fuse 36 in the board behind the glovebox - lower the glovebox lid, squeeze the sides to drop it right down. The fuses are identified on a sheet. It's a 5A fuse.
| RobH69 Member Since: 24 Sep 2014 Location: Dublin, Ireland Posts: 11
thanks for the reply, ya I checked the fuse today and it's okay |
| Couchnomad Member Since: 07 Jan 2015 Location: Staffs Posts: 19
Hi which ones aren't working, front or back? when it happened to mine the front worked ok but there was a problem with the back ones so I bought a replacement as I couldn't here them 'click' when tested, I took the rear bumper off to replace them one by one and found that the furthest offside wiring had broke just before going into the sensor, I fixed this and all was good no more continuous tone.
Have you used a pressure washer on the car recently? Using the jetwash close to the sensors can drown them 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
I've just bought another range rover and they weren't working when I got it, it's strange that the light on the dash isn't on and it's not working whatsoever |
| All times are GMT |
