Home > Maintenance & Modifications > Parking Sensors not working?
RobH69
2008 Range Rover Sport TDV8 HSE Java Black
Hi I was wondering could anyone point me in the right direction, my parking sensors aren't working and the light on the dash is not illuminated at all. What should I check first am I looking at a new module or maybe best case scenario something unplugged?
Thanks in advance.
Rob
Post #459317 Wed Apr 15 2015 10:11pm
First port of call is the fuses. Check fuse 36 in the board behind the glovebox - lower the glovebox lid, squeeze the sides to drop it right down. The fuses are identified on a sheet. It's a 5A fuse.
If the fuse is ok, then you probably need to get a code reader attached and check for fault codes. 2012 SDV6 - it's missing a couple of cylinders
Post #459323 Wed Apr 15 2015 10:32pm
RobH69
thanks for the reply, ya I checked the fuse today and it's okay
Post #459324 Wed Apr 15 2015 10:35pm
Couchnomad
United Kingdom 2005 Range Rover Sport TDV6 HSE Lux Java Black
Hi which ones aren't working, front or back? when it happened to mine the front worked ok but there was a problem with the back ones so I bought a replacement as I couldn't here them 'click' when tested, I took the rear bumper off to replace them one by one and found that the furthest offside wiring had broke just before going into the sensor, I fixed this and all was good no more continuous tone.
Though I did get caught out in France when I turned them off as I was in a multi-story car park and was irritating the hell out off me beeping so I turned them off only to forget to turn them back on and when I returned to the Chalet and parking below it I missed a column in the blind spot and caught the rear bumper on it Big Cry
Is there a fix/upgrade that will reset time back on after a set time? I'm sure that it did it automatically on my previous X5's I've had?? Current RRS 2.7 (de-badged Black) & 335i Cab for the sunny days.
Post #459348 Thu Apr 16 2015 8:14am
Tim in Scotland
Have you used a pressure washer on the car recently? Using the jetwash close to the sensors can drown them 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #459350 Thu Apr 16 2015 8:26am
RobH69
I've just bought another range rover and they weren't working when I got it, it's strange that the light on the dash isn't on and it's not working whatsoever
Post #459365 Thu Apr 16 2015 10:15am
