![]() | Home > Technical > 2 stroke oil in diesel tank tdv6 ?? |
Paul Holywood Member Since: 14 Dec 2013 Location: Hertfordshire Posts: 307 ![]() ![]() ![]() |
I use 50/50 with the best rapeseed oil you can buy.. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9133 ![]() ![]() ![]() |
Sorry to reopen this old wound, but here is some interesting test evidence that suggests no benefit from 2SO and the possibility of injector fouling.
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
Thanks, an excellent article and prompting me to reconsider my previous views. |
I don't see how that article/those tests can prove any more conclusive than the many reporting improvements in fuel consumption.
Agree that lubricity and cetane are slightly improved which is why I have been using it for over 8 years in my vehicles, but my concern was the issue regarding zinc content. Although I have not experienced any issues so far, and I have never heard it raised as an issue before. does all 2SO have the same zinc issue?
I would assume that they will all be broadly similar but it would still be good practice, in my view, to test many different types. Visiting from DISCO3.CO.UK
Just read the report again, zinc content measured was 15 parts per billion!!!! |
I agree completely. |
T'was fine in old fashioned diesel engines with relatively low pressure systems and mechanical injectors.
Well, after all of that filled up with diesel today and added my usual 2SO in the tank. |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
Just had a look at this link, As this issue is that the process cleans carbon from working parts of engine,then the bores and pistons will be cleared of build up of carbon.And on an older engine will result in lower compression. Not a good thing itisme |
Yes Harry, I read all that 8 years ago when I started adding it.
