Home > Technical > 2 stroke oil in diesel tank tdv6 ??
Page 1 of 3 123>
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
hi is it true that if you add 250 ml of 2 stroke oil to a tank of diesel it cleans out the injectors,iv never heard of it before silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #410066 Sat Jan 18 2014 7:33pm
70 pages for a quick browse on the subject Laughing
http://www.freel2.com/forum/topic878.html
Post #410068 Sat Jan 18 2014 7:47pm
gazzc
Thanks Nick .impressive silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #410092 Sat Jan 18 2014 9:00pm
Saeedasghar
2006 Range Rover Sport TDV6 HSE Java Black
There was a big topic on here in regards to the 2 stroke question. My end decision was its better to use high quality fuel and additives such as redex, forte, millers........ with no risk to internal parts or seals. Then risk adding 2 stroke to knacker anything up. Hope this helps Thumbs Up
Post #410109 Sat Jan 18 2014 10:25pm
gazzc
Really can I ask what made u against the 2 stroke oil option as the write up seems so good.thanks for reply.garry silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #410114 Sat Jan 18 2014 10:46pm
The whole 2 stroke debate seems to polarise in to two camps: those that ask for proper evidence of its efficacy and those who just say "I did it after reading about it on the internet and I think my engine is quieter so it must be great".
The idea surfaced in the US as far as I can see. The US isn't at the forefront of diesel technology because they don't really use diesel very much outside of niche vehicles. The idea is that as sulphur was reduced the lubricity of the fuel was reduced. Adding 2 stroke oil is supposed to replace the lubricating properties of the sulphur.
If you look at the lubricity of modern UK/EU diesel fuels you will see that the better quality ones already far exceed the requirements of the testing standards for lubricity. The additive packs do the job of the sulphur or two stroke.
Buy the best fuel you can or buy supermarket fuel and a decent self-dosing fuel additive designed for the job. Sticking some 2 stroke oil in based on dosing info received from a forum member of unknown provenance seems, to me at least, to be rather bizarre behaviour.
I generally run BP Ultimate diesel through my TDV8. I'm not putting any 2 stroke oil in the fuel tank, that's for sure, until I'm given scientific evidence that the claims made by these people are actually verifiable, correct and accurate. 2012 SDV6 - it's missing a couple of cylinders
Post #410122 Sun Jan 19 2014 12:18am
gazzc
ok thanks for reply,not sure if i will bother now silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #410132 Sun Jan 19 2014 9:56am
drdelrrs
In my opinion,as a qualified design engineer, good quality fuel and good quality oils changed regularly is the best route. Drive with some mechanical sympathy - let it fully warm up before using maximum performance and let it idle for a few seconds before switching off.
Post #410150 Sun Jan 19 2014 11:26am
Black Bess
I think I would be concerned about a build up of carbon deposits from adding two-stroke oil, rather than the reverse (I haven`t read the report by the way), also, I would have thought extra lubricating oil in the top-end of the engine (some of which contain metallic additive packs) may well damage the oxidation catalyst in the exhaust and certainly will contaminate the diesel particulate filter on Euro 5 engines.
What a zany idea !!
Post #410310 Mon Jan 20 2014 2:14pm
drdelrrs
The problem is that many of the opinions and suggestions found on the 'Web' are unsubstantiated and the vested interests and/or the qualifications of those posting aren't usually open to scrutiny. I've not seen any objective and controlled tests from reputable laboratories.
Its worth noting that the vast majority of 2-stroke engines are small capacity and air-cooled (there are a few outboards that are water-cooled) . Air-cooled engines run at much higher surface and combustion temperatures than even modern hi-speed diesels. The lubrication characteristics of the oil is formulated to survive and perform at these higher surface temperature. Consequently the chances are that there will be residue in the exhaust that will be deposited on the vanes of the turbo-charger's compressor and the last thing you want to do on a RRS is to shorten the life of your turbo !
Post #410342 Mon Jan 20 2014 5:38pm
gazzc
thats that idea sacked then Rolling Eyes just a thought though. Has any one had a bad experience or any problems adding 2so to diesel silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #410493 Tue Jan 21 2014 6:13pm
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
I have used FC two stroke in my LR3, RRS, BMW X5 and Fiat Ducato Motor home, all bought new and in the case of the LR3 for 5 years since its purchase in 2006 and sale in 2011. X5 from 2006 and still have and it gets its dose at every fill.
I have never had a problem and use it for two reasons:
1. Lubrication of the high pressure pump (Many failed including my sons vehicle after sulphur was removed from diesel, a bit more lubrication has upside but no downside that I have experienced)
2. A slightly higher Cetane level which contributes to smoother running.
Can't comment on any other nebulous claims.
Regards
Barryp 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #410745 Thu Jan 23 2014 4:47am
gazzc
is there any specific 2so or can you add any brand silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #410749 Thu Jan 23 2014 9:00am
Barryp
2 stroke has various standards applied to it, I use FC but others are happy with FB.
I don't think the brand matters although I always use Castrol. Look for FC which is semi synthetic in the oil spec, I understand FB is mineral oil.
Regards
Post #410886 Fri Jan 24 2014 7:29am
BKHK
What ratio 2 stroke to fuel do you use Barry? Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #410895 Fri Jan 24 2014 9:12am
Page 1 of 3 123>
