| RRSPORT.CO.UK | ||
|  | Home > General > Flat Battery.... Charging at 15.1v...? Regulator Fault...? |
| darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442      |
 Afternoon all!
|  Sat Apr 04 2015 5:17pm |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477    | More likely to be at that voltage because the battery is bad. It's not quite too high, just at the upper limit.  | ||
|  Sat Apr 04 2015 6:10pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | It will charge at 15v if the battery is low on charge
|  Sat Apr 04 2015 6:17pm |
| darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442      | Battery charger had charged the battery within a couple of hours.
|  Sat Apr 04 2015 6:33pm |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477    | gogsy, I don't think you'll find many automotive batteries are Gel. They wouldn't be compatible with the RRS as the life would be reduced by the higher charging voltages.  | ||
|  Sun Apr 05 2015 9:00am |
| darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442      | Morning All....
|  Sun Apr 05 2015 10:56am |
| LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227      | Your picture shows a wet cell battery, have you checked the liquid level in the cells, as Gogsey1956  says?
|  Sun Apr 05 2015 11:20am |
| darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442      | No egg sucking here!!    | ||
|  Sun Apr 05 2015 11:36am |
| Robbie Member Since: 12 Mar 2006 Location: Waiting for my old avatar to be allowed back... we miss her! Posts: 73    | It can take 12 hours or more to charge and condition the battery, so your brief charge may have done little.  The battery itself could be a fair age too; quite a few types have the year stamped on top of the battery terminals, so worth checking.
|  Sun Apr 05 2015 11:39am |
| darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442      | There is a date stamped on the metal holder that holds the battery in:  25 03 10
|  Sun Apr 05 2015 1:36pm |
| LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227      | Sorry for delay been out for lunch!!
|  Sun Apr 05 2015 2:40pm |
| darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442      | How far down should the water be? In the chamber I can see a slight lip, with fluid slightly underneath (with the exception of 1 chamber where the fluid is above the lip).
|  Sun Apr 05 2015 3:10pm |
| LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227      | When you look into each cell you can see the top of the plates about an inch down. The water should be just covering the plates. | ||
|  Sun Apr 05 2015 4:08pm |
| darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442      | Can't see any plates, just a slight lip that sticks out sidewards slightly. Had a bit of a Google and I think that's the fill level lip??
|  Sun Apr 05 2015 4:20pm |
| Posting Rules
 the voltage monitoring system.
