![]() | Home > General > Flat Battery.... Charging at 15.1v...? Regulator Fault...? |
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 ![]() ![]() ![]() |
Afternoon all!
More likely to be at that voltage because the battery is bad. It's not quite too high, just at the upper limit. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4518 ![]() ![]() ![]() |
It will charge at 15v if the battery is low on charge
Battery charger had charged the battery within a couple of hours.
gogsy, I don't think you'll find many automotive batteries are Gel. They wouldn't be compatible with the RRS as the life would be reduced by the higher charging voltages. |
Morning All....
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 ![]() ![]() ![]() |
Your picture shows a wet cell battery, have you checked the liquid level in the cells, as Gogsey1956 says?
No egg sucking here!! |
Robbie Member Since: 12 Mar 2006 Location: Waiting for my old avatar to be allowed back... we miss her! Posts: 73 ![]() ![]() |
It can take 12 hours or more to charge and condition the battery, so your brief charge may have done little. The battery itself could be a fair age too; quite a few types have the year stamped on top of the battery terminals, so worth checking.
There is a date stamped on the metal holder that holds the battery in: 25 03 10
Sorry for delay been out for lunch!!
How far down should the water be? In the chamber I can see a slight lip, with fluid slightly underneath (with the exception of 1 chamber where the fluid is above the lip).
When you look into each cell you can see the top of the plates about an inch down. The water should be just covering the plates. |
Can't see any plates, just a slight lip that sticks out sidewards slightly. Had a bit of a Google and I think that's the fill level lip??
