![]() | Home > Technical > 2006 range rover sport tdv6 gearbox/trasmission oil change? |
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961
This is quite a common subject, if you do a search you will find lots of threads relating to this subject. The thing to remember is that a simple drain and refill only changes half the oil in the gearbox, a lot of people swear by a megaflush which will replace all of the old oil with new. I have had mine done and would recommend to anyone,,, go for some Dr tranny and a gearbox reset as well |
| jonesy_boys Member Since: 18 Oct 2013 Location: cardiff Posts: 45
When you refill the oil has the car got to be level or the bottom of the tray? |
i would imagine the car would have to be level,,,, or near enough level 2010 RRS, TDV8
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477
The transmission must be between 30 and 35 degrees to ensure the level is correct. With the engine running (or you'll get a soaking), it's fill to spill. |
Ok thanks for your help. I'm gunna try and do it myself, sorry does the gearbox need to be level or the bottom of the tray? As the gearbox is running up. Thanks again. |
Not quite sure what you mean exactly by gearbox level or the bottom of the tray?
Sorry, when I come to refill the gearbox has it got to be level or have I got to jack the veichle up so the box or the bottom of the oil tray is level? Do you understand what I mean? Or do you you just refill as the vehicle is sat? Cheers dean |
| myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433
Car has to be level, note also that the oil temperature is important but you can search this forum for that information. |
Ok, with the car level the gearbox will be running up slightly is that right? Or shall I put a level on the oil tray of the gear box and jack it up till that's level? Thank again dean |
| gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494
dont jack anything up mate just keep the car level |
Does anyone know an easy way of changing the transmission fluid? I've changed it but I carnt get the right amount of fluid right. It keeps dropping gears |
So, you need to get the transmission oil temp between 35 and 50 degrees. Doesn't take long to warm up.
Hi guys I've tried everything you've all said again today but no luck. It goes up the gears fine if you boot it. But if you accelerate slowly and go up the gears it keeps jumping back and for third and forth gears:/ then the transmission fault appears on the dash board. |
What mileage is it at? Visiting from DISCO3.CO.UK
| All times are GMT |
