Home > General > Couple of questions from a new owner :)
Si-W85
Hi ok so I picked up my RRS sc on Saturday and I have a couple questions hope somebody can help.
1. Is there a way of making the indicator one touch for 3 blinks rather than just the once?
2. Battery was dead before i picked it up and is now showing HDC fault could it be low vaultage if so I have a battery reconditioner will that restore it?
3. Is there any Electrical mods I can do to update the system (2006) as my previous car was an Audi so was able to add things like dial sweep, speedo on sat nav screen, mirror dip in reverse, beep on lock/ unlock
4. Take me home lights only light up when lock is there a way of making the lights come on when unlocked?
Sorry for all the questions thought it better to ask in one thread
Post #456998 Tue Mar 24 2015 9:22am
zaphod
1. Yes - see this thread: http://www.rrsport.co.uk/forum/topic27997.html?highlight=
2. I had the same fault on mine when I first went to view it. Dealer put a new battery in it and after the drive home it disappeared. Give the charger a go to make sure the battery is fully charged - the RRS really doesn't like having fluctuating voltage.
3. Mirror dip on reverse... not sure if it is standard but my SC does this - you can enable it from the settings accessible by pushing the button in the end of the indicator stalk. Don't think the other things are possible.
4. Don't think so but you can program the Land Rover button on your fob to make them come on whenever it's pressed Thumbs Up
Post #456999 Tue Mar 24 2015 9:38am
Lost for Words
Re: Couple of questions from a new owner :)
As Zaphod pointed out, this can be done - it requires updating the Body Control Module software and editing the CCF (Car Configuration File). Thumbs Up
It's worth a try. I would suggest you remove the battery from the car if doing a conditioning charge. If you do need a new one, go for this: http://www.tayna.co.uk/EA1000-Exide-Premiu...P7488.html. Use discount code D2BOYS. Wink
Guage sweep doesn't work, speedo - no, as said, mirror dip should be selectable from the instrument pack, the chirp or horn on locking options are in the CCF but I don't know if they work.
There's no way, to my knowledge of programming it other than the 3rd key button. Interior lights will come on when the car is unlocked so, if you really wanted to, you could wire something up with a few relays etc. Thumbs Up Visiting from DISCO3.CO.UK
Post #457000 Tue Mar 24 2015 10:14am
itsmeagain
I activated the beep on lock/unlock but turned it off today as it was annoying me.
You will need to either purchase an IID tool or get someone to do it for you. Current 2010 Range Rover Sport HSE with the usual toys: timed climate, Rosen headrest screens, tow bar with twin electrics, Blackvue HD cam
2008 Seat Leon K1
2012 Audi A1 2.0litre Black Edition TDI
2004 Audi A4 convertible
2004 Audi A2 TDI
Post #457004 Tue Mar 24 2015 10:23am
Si-W85
Thanks so much for the replies Bow down
I would like to do all those mods in the link provided as they are something I do miss, the knowing when the lights are on is also very handy, and the clock on dash would be good also as it looks a little bare on the little digital screen also the sat nav whilst on the move is a very good mod which will be needed. I will take the battery off and stick it on our battery reconditioner, will I loose any settings or radio codes etc etc if so would it be better to leave on the car and charge? Cheers
Post #457008 Tue Mar 24 2015 11:05am
Lost for Words
No radio codes to worry about. Clock will need resetting. Thumbs Up Visiting from DISCO3.CO.UK
Post #457009 Tue Mar 24 2015 11:19am
Si-W85
Ok that's cool will take it off and stick it on the conditioner then Wink
Post #457011 Tue Mar 24 2015 11:21am
Bodsy
Site Sponsor
Si,
these are the updates as shared in that link to my other thread that I can do as well as the BT update. Thumbs Up
Ian Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #457012 Tue Mar 24 2015 11:26am
Si-W85
Thanks Ian I have sent you a pm Thumbs Up
Post #457013 Tue Mar 24 2015 11:35am
