![]() | Home > General > Couple of questions from a new owner :) |
zaphod Member Since: 16 Jan 2015 Location: Liverpool Posts: 290 ![]() ![]() ![]() |
1. Yes - see this thread: http://www.rrsport.co.uk/forum/topic27997.html?highlight=
As Zaphod pointed out, this can be done - it requires updating the Body Control Module software and editing the CCF (Car Configuration File). ![]()
It's worth a try. I would suggest you remove the battery from the car if doing a conditioning charge. If you do need a new one, go for this: http://www.tayna.co.uk/EA1000-Exide-Premiu...P7488.html. Use discount code D2BOYS. ![]()
Guage sweep doesn't work, speedo - no, as said, mirror dip should be selectable from the instrument pack, the chirp or horn on locking options are in the CCF but I don't know if they work.
There's no way, to my knowledge of programming it other than the 3rd key button. Interior lights will come on when the car is unlocked so, if you really wanted to, you could wire something up with a few relays etc. ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
itsmeagain Member Since: 01 Nov 2012 Location: Birmingham Posts: 222 ![]() ![]() ![]() |
I activated the beep on lock/unlock but turned it off today as it was annoying me.
Si-W85 Member Since: 22 Mar 2015 Location: Huddersfield Posts: 109 ![]() |
Thanks so much for the replies |
No radio codes to worry about. Clock will need resetting. |
Ok that's cool will take it off and stick it on the conditioner then |
Si,
Thanks Ian I have sent you a pm |
