![]() | Home > Technical > Suspension Knock, Mass Dampers |
johnunleashed Member Since: 13 Jul 2014 Location: Lancashire Posts: 59 ![]() ![]() |
Hi it does not have the cast steel blocks , fitted |
Thanks BOB i will get a set , many thanks for your time |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8879 ![]() ![]() ![]() |
Well that's interesting. Mine has them fitted so I guess a previous owner must have complained.
Hi they bolt on with two bolts , jack up car 10min each side ,DIY job , thanks again 2007 SUPERCHARGED HST |
Fair enough. Not sure I'd be wanting to unbolt the body from the chassis on my driveway but good luck with it! |
you don't have to the blocks just bolt to the chassis , they don't do anything apart from stop the sound , the holes are already in the chassis 2007 SUPERCHARGED HST |
I think the blocks sit over the chassis rails and the bolts just locate them. They are free swinging when in place - that's how they work. In order to get them in you'd need to lift the rear of the body to give clearance. At least, that was my understanding from previous discussions about these blocks.
yes the blocks at the back are std , but the ones at the front are the add on for the knock noise that drives you mad lol 2007 SUPERCHARGED HST |
ccmpaul Member Since: 09 Nov 2014 Location: Middlesbrough Posts: 4 ![]() ![]() ![]() |
Hi,any thought on my knock! I replaced the lower wishbones but I still have the same knock, the car rides without noise and can go up speed bumps without noise, but if the wheels go down into a pot hole or man hole lid the front end makes a cluck, I've had it back to garage that replaced the wishbones but they said there no play on any joints that would make this sound, could it be the mass damper, will these be fitted to my 05 supercharger ? Paul |
hse-lee Member Since: 17 Jan 2015 Location: london Posts: 77 ![]() ![]() ![]() |
having recently replaced the spare wheel winch myself and with a knocking car driving me mad and garage bills coming round before you can blink I'm considering fitting these myself question
PAS Member Since: 30 May 2014 Location: kent Posts: 70 ![]() ![]() ![]() |
yes it really is that easy.get them from stealers.£70 ish.don't need to remove anything |
Hi got mine off ebay for £30 brand new ,30 min job very easy , any prob just ask 2007 SUPERCHARGED HST |
Bob. Member Since: 03 Feb 2009 Location: SWest Posts: 275 ![]() ![]() |
If you look at the pictures on page 1 of this thread which I posted some years back, you can see the bolts which hold each damper in place. |
If you where close to me would help you fit them m8 2007 SUPERCHARGED HST |
