Home > Technical > Suspension Knock, Mass Dampers
Page 2 of 3 <123>
johnunleashed
2007 Range Rover Sport Supercharged HST Java Black
Hi it does not have the cast steel blocks , fitted
Post #438955 Thu Oct 09 2014 9:30pm
Bob.
My 2007MY TdV8 was the first customer's car to be fitted with the mass dampers and that was done on 5 Nov 2009. New build cars had them fitted later.
A 2007 build car would not have had them from new and they would only have been fitted if a customer complained about knocking. Not all cars knocked so not all earlier cars have had them retrofitted.
Hope this helps.
Post #438960 Thu Oct 09 2014 9:49pm
johnunleashed
Thanks BOB i will get a set , many thanks for your time Very Happy
Post #438970 Fri Oct 10 2014 6:48am
Well that's interesting. Mine has them fitted so I guess a previous owner must have complained.
I think they need the body lifting to fit them so might not be a DIY job... 2012 SDV6 - it's missing a couple of cylinders
Post #439060 Sat Oct 11 2014 2:10am
johnunleashed
Hi they bolt on with two bolts , jack up car 10min each side ,DIY job , thanks again 2007 SUPERCHARGED HST
Post #439068 Sat Oct 11 2014 8:38am
Fair enough. Not sure I'd be wanting to unbolt the body from the chassis on my driveway but good luck with it! Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #439071 Sat Oct 11 2014 10:14am
johnunleashed
you don't have to the blocks just bolt to the chassis , they don't do anything apart from stop the sound , the holes are already in the chassis 2007 SUPERCHARGED HST
Post #439076 Sat Oct 11 2014 10:32am
I think the blocks sit over the chassis rails and the bolts just locate them. They are free swinging when in place - that's how they work. In order to get them in you'd need to lift the rear of the body to give clearance. At least, that was my understanding from previous discussions about these blocks.
Edit: I think there are two types. There are some at the rear of the vehicle that wrap over the chassis and then there are those that bolt to the chassis somewhere else. I think we've been talking about different blocks! My apologies. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #439077 Sat Oct 11 2014 10:35am
johnunleashed
yes the blocks at the back are std , but the ones at the front are the add on for the knock noise that drives you mad lol 2007 SUPERCHARGED HST
Post #439079 Sat Oct 11 2014 10:44am
ccmpaul
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
Hi,any thought on my knock! I replaced the lower wishbones but I still have the same knock, the car rides without noise and can go up speed bumps without noise, but if the wheels go down into a pot hole or man hole lid the front end makes a cluck, I've had it back to garage that replaced the wishbones but they said there no play on any joints that would make this sound, could it be the mass damper, will these be fitted to my 05 supercharger ? Paul
Post #442043 Sun Nov 09 2014 8:29pm
hse-lee
having recently replaced the spare wheel winch myself and with a knocking car driving me mad and garage bills coming round before you can blink I'm considering fitting these myself question
in offroad height will i have enough access to get under and do what simply looks like align damper and bolt in place
secondly is it really that easy Laughing
do you have to remove the undertray to do this and I've googled mass damper kit but can't seem to find it anywere is it a landrover only job to get the parts
I'm starting to think after 3 months of owning this car i had better get more confident with a spanner or deeper pockets Big Cry Big Cry
Post #456472 Thu Mar 19 2015 7:34pm
PAS
England 2008 Range Rover Sport TDV8 HSE Santorini Black
yes it really is that easy.get them from stealers.£70 ish.don't need to remove anything
Post #456478 Thu Mar 19 2015 8:21pm
johnunleashed
Hi got mine off ebay for £30 brand new ,30 min job very easy , any prob just ask 2007 SUPERCHARGED HST
Post #456485 Thu Mar 19 2015 9:43pm
Bob.
If you look at the pictures on page 1 of this thread which I posted some years back, you can see the bolts which hold each damper in place.
Post #456489 Thu Mar 19 2015 10:34pm
johnunleashed
If you where close to me would help you fit them m8 2007 SUPERCHARGED HST
Post #456505 Fri Mar 20 2015 7:33am
Page 2 of 3 <123>
