| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > Long shot EGR blank plea...Bristol...! |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477    | If it's any good to you, I might be able to help if you could come here (Warminster).  | ||
|  Thu Mar 12 2015 8:49am |
| JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186      | Not sure if the EGR's on a 2007 RRS can be blanked. 2014 L405 SDV8 RR Autobiography  | ||
|  Thu Mar 12 2015 9:09am |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329    | If your having a remap, then think about going down the BAS route.    | ||
|  Thu Mar 12 2015 9:28am |
| flack Member Since: 24 Feb 2013 Location: Preston Posts: 379  | Not on 2007 it needs to fitted with emulators and blanked off.
 They can.   In addition to the physical blanks, the software must be modified to prevent the engine MIL from illuminating. A basic method it simply to remove the EGR function from the software full stop but the best solution is to fit EGR emulators and modify the software to accept these. That way, the car and/or any diagnostic tool will simply see them as fully functioning valves.   https://secure.bellautoservices.co.uk/stor...-20072009/ Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver   | ||
|  Thu Mar 12 2015 9:31am |
| Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246      | Guys!.....thanks so much for the swift replies!
|  Thu Mar 12 2015 10:15am |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477    | Yep, no problem.  | ||
|  Thu Mar 12 2015 10:30am |
| Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246      | .....pm'd you LFW.   | ||
|  Thu Mar 12 2015 1:33pm |
| Posting Rules
