![]() | Home > Maintenance & Modifications > Long shot EGR blank plea...Bristol...! |
If it's any good to you, I might be able to help if you could come here (Warminster). |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
Not sure if the EGR's on a 2007 RRS can be blanked. 2014 L405 SDV8 RR Autobiography |
If your having a remap, then think about going down the BAS route. |
Not on 2007 it needs to fitted with emulators and blanked off.
They can. ![]() In addition to the physical blanks, the software must be modified to prevent the engine MIL from illuminating. A basic method it simply to remove the EGR function from the software full stop but the best solution is to fit EGR emulators and modify the software to accept these. That way, the car and/or any diagnostic tool will simply see them as fully functioning valves. ![]() https://secure.bellautoservices.co.uk/stor...-20072009/ Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246 ![]() ![]() ![]() |
Guys!.....thanks so much for the swift replies!
Yep, no problem. |
.....pm'd you LFW. |
