Home > In Car Electronics > Which In Car Camera do you recommend??
Page 3 of 4 <1234>
maybe so, but your insurance company (iirc yourself also at a cost) can look to see who insures the car and put in a claim for the repair, if the number plate is caught
Post #412819 Thu Feb 06 2014 12:39pm
Steve44
United Kingdom 2009 Range Rover Sport TDV6 HSE Santorini Black
scary wrote:
the problem i see in having the motion/g sensor on is that in most cases the car park will be on private ground so there's not much the police can do if any damage is caused to your vehicle whether caught on camera or not.
Someone hit the back of my motor ( a motorhome not RRS) when getting diesel at local supermarket but luckily a local taxi driver took his number plate number as he left the garage without stopping. Contacted the police and as you said they were not very interested but given the details we had they tracked down the Censored and helped the insurance company sort out the claim. 2009 RRS TDV6 2.7 HSE Santorini Black
Post #412883 Thu Feb 06 2014 6:18pm
V8SC
2006 Range Rover Sport Supercharged Bonatti Grey
Good enough reason here to get a camera fitted !
http://home.bt.com/lifestyle/motoring/moto...3871648307 Carl
Post #412929 Thu Feb 06 2014 11:44pm
scarey
loads of russian dashcam videos on you tube..
Post #412941 Fri Feb 07 2014 8:50am
andy r
2008 Range Rover Sport TDV6 S Zambezi Silver
Those Rusky ones on youtube are a bit scary.........dont bother with the camera, just have a pickaxe handle in prominent view ! 08 2.7 RRS "S"
Td5 110......very modified
RS 5
Kawasaki ZX12R Censored me, it's quick !
Post #412962 Fri Feb 07 2014 12:56pm
Kklone
I'll definitely be getting one ASAP after a bit of a brown trouser moment yesterday, so many idiots - so little road. Need....more.....mud, must.....off.....road.
Post #413345 Mon Feb 10 2014 6:08pm
big pimp
I have both the 400 and the 500 blackvue.
The 400 is much slimmer and neater, compared to its fatter wifi brother! MY10 HSE 3.0 TDV6 : Santorini Black : Ebony Interior w/Anigre wood : Privacy Glass (total) : Sunroof : Sidesteps : Hybrid TV : Detachable Tow Kit : Spare Wheel Cover : 22" Dished Supersports
Post #413366 Mon Feb 10 2014 7:50pm
muddywheels
Milk Float Man
Wifi version is bigger but beats removing unit to check card Thumbs Up Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #413372 Mon Feb 10 2014 8:07pm
kok23
United Kingdom 2013 Range Rover Sport 4.4 V8 HSE Lux Firenze Red
Re: Which In Car Camera do you recommend??
Siberianfox wrote:
Just wondering which in car camera I need to be buying.
My technical knowledge on stuff like this is a big girlie zero! Embarassed
Any recommendations would be great.
Thanks
Foxy x
If you have a smartphone, then chances are you could use that.
I use my Galaxy S2, with Samsung car mount (which has a hole that the camera can see through.) You can also get black box apps that use GPS data to show where you are on a map, and the speed you were doing at the time.
However, if you'd like a dedicated dashcam with reasonable price, take a look at: http://www.szswill.com
Post #420359 Sat Apr 05 2014 2:30pm
defender_uk
England 2013 Range Rover Sport SDV6 Autobiography Firenze Red
been researching then all night and more muddled than ever!!
I want a two cam system...back window not car interior, that are moveable between cars...works, RRS and Defender and one that doesn't completely take over the cigarette lighter as that is needed for the Satnav!!!
Am I being too demanding???
Post #452956 Wed Feb 18 2015 11:02pm
defender_uk
Post #452957 Wed Feb 18 2015 11:03pm
Paddi
Perhaps you could try a couple of Mini 0803 cameras?
These little cameras are inexpensive at about £90 each and can easily be removed from the windscreen mount. To avoid monopolising the power outlets you would have to use a hard wiring kit (available direct from China for less than a fiver) the power only needs to be supplied to the windscreen mount so no plugs to remove when you take out the camera.
You would need to buy windscreen mounts for each vehicle. There are two versions without/with GPS priced at about £5 and £15 respectively. 2008 MY Java Black TDV8 HSE
Post #453899 Thu Feb 26 2015 1:57pm
Ian.H
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
I've installed the front camera (not got to hooking the rear one up yet) of a MIWitness system to both my RRS and my Fiancées Golf.. both seem to work pretty well, and with the WiFi module and the likes of Transmit app for my iPhone, I can transfer video files from the camera to either my unix servers via SCP, or to my cloud servers via owncloud / webdav etc... although doing that for many files will take a while.
Here's an example of one snippet I captured of someone who obviously isn't quite sure what those shiny reflective things both inside and hanging off the corner of the doors are for:
https://cloud.digihub.eu/index.php/s/d20cb...233c16e523
Cheers..
Ian
Post #453907 Thu Feb 26 2015 2:41pm
defender_uk
Any comments on Blackvue and DAB radios? Most people seemed to think it was the best cam, but never mentioned you can't use the radio with them. Especially if you have a DAB radio....completely incompatible....n it also Censored up FM but not as bad. Very disappointed n annoyed that no where mentioned at all this incompatibility.
any way to sort this mess?
thanks
Post #460164 Wed Apr 22 2015 6:57pm
defender_UK
Slightly confused here are you saying if you have your Blackvue Camera operating your radio won't work. As I have Blackvue front and rear cameras fitted and they certainly don't interfere with radio reception be it DAB or FM in fact the the Blackvue Audio actually records what is playing on the radio on to the SD card.
Post #460178 Wed Apr 22 2015 10:23pm
Page 3 of 4 <1234>
