![]() | Home > General > light whirring sound ??? |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Hi Folks, my RRS drives beautifull but above 25 mph it has a slight whirring sound. Now it does not increase or fluctuate when engine is reved up or with road speed, so what is it ? is it the ACE pump (if there is one) is it the torque convertor, or is it me |
possibility ! thanks for that |
Hi folks, still got this whiring noise between 30 - 50 mph. Its not the tyres and it doesn't increase with the engine revs or vehicle speed, it's very annoying but can anyone suggest any ideas on this one please. Idid wonder if it could be torque convertor related as this is only a word to me, cheers |
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 ![]() ![]() ![]() |
Someone mentioned before prop shaft bearing. Is the whirring on acceleration? Does it go when you lift the gas pedal? Or does it whir when realising the gas pedal on over run? If the lter it could be doff related otherwise propshaft bearing might be a good start to check. I'm not Fat. RRS TDV6 HST. |
Hi Joe, thanks for the reply, it's just annoying at the moment and it's done it for the last three months. The sound is more like a spooky whiring sound you would here on a Dr Who episode |
Weird if its there both on acceleration and deceleration. What tyres you got on? When this noise happens is your Econ button on or off? I'm not Fat. RRS TDV6 HST. |
Hi again, its got general grabbers all round on it at present and I my econ button is turned off, its a strange one this mate. The crazy thing is that it doesn't speed up or slow down its only there between these speeds and sounds like its somewhere underneath if that helps |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9074 ![]() ![]() ![]() |
Grabber AT? They are known for making a droning noise at that speed range... 2012 SDV6 - it's missing a couple of cylinders
Cheers for that, is it these tyres in general or do tyre pressures contribute ?? |
The AT seems to be a noisy tyre at a couple of speeds. Around the 30-40mph range as you've mentioned and again around 60-70mph. Both of which are annoying as they coincide with common cruising speeds in most countries.
Hi , I have Grabber GT on the rear and Grabber UHP on the front, this is all double dutch to me so please help !! 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Ah, I'm talking about the AT which is somewhat chunkier than either of those tyres. I tend to run at LR's recommended pressures +2psi as I'm running a slightly deeper sidewall (55% rather than 50% aspect ratio). 2012 SDV6 - it's missing a couple of cylinders
All my tyres are excellent but not sure if they are cheapies or decent ones ! |
Hi again, could it be the viscous fan whirring as it stays at the same pitch ?? |
