Home > General > light whirring sound ???
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Hi Folks, my RRS drives beautifull but above 25 mph it has a slight whirring sound. Now it does not increase or fluctuate when engine is reved up or with road speed, so what is it ? is it the ACE pump (if there is one) is it the torque convertor, or is it me Embarassed I know its a boring one but any ideas or if any one else has had this would be interesting Thumbs Up Just to add diffs are fine and also wheel bearings...
Post #442411 Thu Nov 13 2014 10:30am
Camelrock
Could it be tyre noise ?? 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #442417 Thu Nov 13 2014 11:19am
Gornal Hills
possibility ! thanks for that Thumbs Up
Post #442433 Thu Nov 13 2014 2:21pm
Gornal Hills
Hi folks, still got this whiring noise between 30 - 50 mph. Its not the tyres and it doesn't increase with the engine revs or vehicle speed, it's very annoying but can anyone suggest any ideas on this one please. Idid wonder if it could be torque convertor related as this is only a word to me, cheers Bow down 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #452959 Wed Feb 18 2015 11:20pm
FatJoe
United Kingdom 2006 Range Rover Sport TDV6 HST Java Black
Someone mentioned before prop shaft bearing. Is the whirring on acceleration? Does it go when you lift the gas pedal? Or does it whir when realising the gas pedal on over run? If the lter it could be doff related otherwise propshaft bearing might be a good start to check. I'm not Fat. RRS TDV6 HST.
Post #452962 Wed Feb 18 2015 11:49pm
Gornal Hills
Hi Joe, thanks for the reply, it's just annoying at the moment and it's done it for the last three months. The sound is more like a spooky whiring sound you would here on a Dr Who episode Embarassed but it doesn't go away when decelerating, its between about 30 - 50 mph but vanishes any slower or faster than that. Also it doesn't speed up or slow down with engine or road speed it just comes and goes, that is why I wondered if it could be the torque convertor. I wasn't sure if the torque convertor speeds up and down with engine speed or stays the same, but she's lovely and smooth on the road. Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #452976 Thu Feb 19 2015 8:58am
FatJoe
Weird if its there both on acceleration and deceleration. What tyres you got on? When this noise happens is your Econ button on or off? I'm not Fat. RRS TDV6 HST.
Post #452978 Thu Feb 19 2015 9:13am
Gornal Hills
Hi again, its got general grabbers all round on it at present and I my econ button is turned off, its a strange one this mate. The crazy thing is that it doesn't speed up or slow down its only there between these speeds and sounds like its somewhere underneath if that helps Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #453002 Thu Feb 19 2015 2:05pm
Grabber AT? They are known for making a droning noise at that speed range... 2012 SDV6 - it's missing a couple of cylinders
Post #453004 Thu Feb 19 2015 2:38pm
Gornal Hills
Cheers for that, is it these tyres in general or do tyre pressures contribute ?? Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #453005 Thu Feb 19 2015 3:15pm
The AT seems to be a noisy tyre at a couple of speeds. Around the 30-40mph range as you've mentioned and again around 60-70mph. Both of which are annoying as they coincide with common cruising speeds in most countries.
There are a number of mentions about it on Disco3. Some report the Cooper LTZ is better in this regard. 2012 SDV6 - it's missing a couple of cylinders
Post #453014 Thu Feb 19 2015 4:50pm
Gornal Hills
Hi , I have Grabber GT on the rear and Grabber UHP on the front, this is all double dutch to me so please help !! 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #453026 Thu Feb 19 2015 6:06pm
Ah, I'm talking about the AT which is somewhat chunkier than either of those tyres. I tend to run at LR's recommended pressures +2psi as I'm running a slightly deeper sidewall (55% rather than 50% aspect ratio). 2012 SDV6 - it's missing a couple of cylinders
Post #453047 Thu Feb 19 2015 8:31pm
Gornal Hills
All my tyres are excellent but not sure if they are cheapies or decent ones ! Confused 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #453052 Thu Feb 19 2015 9:02pm
Gornal Hills
Hi again, could it be the viscous fan whirring as it stays at the same pitch ?? Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #454170 Sat Feb 28 2015 7:38pm
