Home > General > While the car was up in the air...
B9BS X
Took the RRS to get the wheels aligned and while it was up in the air we found a broken wire near the front passenger's side wheel area but cant find were it broke from?
Could this be related to the airbag as the airbag light is on and have already checked the switches/plugs under the seat and have also replaced the airbag clockspring?
 RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #450566 Sat Jan 31 2015 5:31pm
Disco_Mikey
Brake pad wear sensor Thumbs Up
Post #450567 Sat Jan 31 2015 5:39pm
B9BS X
Thanks Disco Mikey
Is this wire only on the one side as this was clipped onto the yellow clip pictured but there isn't one on the other side nor any brake warning messages?
Could this also throw of the airbag light?
Bodsy has changed the air bag clockspring and airbag light still on? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #450569 Sat Jan 31 2015 5:44pm
simple1
It goes onto the sensor that's clipped to the brake pad. No a chance it's airbag related. Mine had an issue with airbag light coming on and off, was always after car been to dealer. Loom was damaged to seat belt tensioner, obviously during the many seat base changes. Whistle This was the only time the seat was moved as most techs at dealer were vertically challenged. Rolling with laughter 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #450572 Sat Jan 31 2015 6:04pm
B9BS X
Would a warning light come on due the wire torn as I have no brake pad warning light come on or do the rrs not come with brake pad warning lights?
Also wat is the other wire that's bolted on? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #450585 Sat Jan 31 2015 6:50pm
simple1
If you earth the wire your pad warning light will come on. Rolling Eyes
Wat is the other wire bolted? Wat??? Oh Birmingham, says it all........ Whistle it's the wheel motion sensor also know as ABS sensor. That's AssistedBraking System incase you ask. Rolling with laughter Bow down 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #450606 Sat Jan 31 2015 8:59pm
Disco_Mikey
Anti-Lock Braking System Thumbs Up
Post #450611 Sat Jan 31 2015 9:24pm
