Home > Technical > Sub Woofer rattle
gazza500
Jersey 2008 Range Rover Sport TDV6 HSE Chawton White
Sub Woofer rattle
Hi Guys,
I have the Logic 7 system in my RRS.
With the subwoofer control set to just over half (can't have it higher) and bass at 3/4 I get a rattle from the damn thing on all music with a heavy baseline.
Is there any fix for this simple or complex? (Apart from turning down the volume and deselecting bass/Subwoofer) Chawton White TDV6 HSE with Alpaca and Rodium, Automatic Climate Control,
Privacy Glass, 22 inch, Hawke Alloy Wheels, Brembo Front Brakes, Premium ICE Pack, Clear repeaters, Chrome Driving Light Surrounds, Tasmods, Chrome handles, HST Grille, Chrome Side Vents, JE ECU Upgrade
Post #181983 Sat Aug 09 2008 4:12pm
might be the low bass note rattling something like a loose jack or a panel
There is a CD that you can buy, which plays different sounds and different bass levels and its designed to find those annoying rattles, I think one of the lads of Freel2.com bought one and they cost about £10
Post #181986 Sat Aug 09 2008 4:20pm
ChrisH
2008 Range Rover Sport TDV8 HSE Rimini Red
I had this with my Logic 7, turned out to be a faulty sub. Get the dealer to check it out, mine was replaced under warranty and its much better now.
Post #182045 Sat Aug 09 2008 9:59pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Stealer job Thumbs Up L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #182060 Sun Aug 10 2008 12:03am
Murdered out
United States 2008 Range Rover Sport 4.4 V8 HSE Java Black
your speaker is blown. Thats what that noise is....
Post #182063 Sun Aug 10 2008 5:10am
gadgetJunky72
2005 Range Rover Sport TDV6 HSE Java Black
hi gazza500.
did you get this sorted as i'm having a similar issue?
thanks
Pav
Post #425235 Sun May 25 2014 7:15pm
HICKY555
England 2008 Range Rover Sport TDV6 HSE Alaska White
I get the same problem when playing Dr DRE or 50 Cent!!! its even worse outside the car, the tailgate rattles Big Cry RANGE ROVER SPORT 2008
White is the new Black
Post #425274 Mon May 26 2014 9:00am
mse
I had this, they replaced all the clips and that fixed it - dealer job Mike
2014 Facelift Discovery
Post #425340 Mon May 26 2014 10:19pm
muddywheels
Milk Float Man
Mine has been replaced once but still not right so going to ask for it looked at again next time it's in Rolling Eyes Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #425343 Mon May 26 2014 10:41pm
michaelsanderson
England 2011 Range Rover Sport SDV6 HSE Fuji White
Mine too
Resurrecting an old thread I know.. did anyone cure this fully?
Mine's terrible. It's not under LR warranty any more but I'm not shy so I don't have a problem stripping the tailgate which is my next job if you guys can't give me an easy answer...
The tailgate rattles itself to death with the sub on anything above half, and you can hear it with the tailgate open too - so it's nothing in the boot. It comes from the section where the sub is mounted - and it's not the number plate on the outside either.
I was going to strip it and tighten everything and dynamat some of it but I don't want to soundproof the bass into the tailgate!
Post #450294 Thu Jan 29 2015 9:29pm
muddywheels
Milk Float Man
I've had mine done twice. They trashed the trim and had to replace it both times but it still rattles above half so I've given up Big Cry
No doubt by now it's been identified as a "Characteristic" Rolling Eyes Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #450306 Thu Jan 29 2015 10:51pm
michaelsanderson
woofington
Thanks for the reply. You've put me off stripping mine down now lol.
I might see what leeds car audio say about it. Make it someone elses problem then if they trash the trim it's their thing to fix rather than mine.
Post #450309 Thu Jan 29 2015 11:06pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
I had the same issue of vibration and rattle but both are relatively easy to fix and I have put a post in tips and tricks to explain.
Post #565724 Sun Sep 23 2018 9:58am
