![]() | Home > Technical > Windscreen Washer Jets |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1070 ![]() ![]() |
I push the button and the water squirts onto the screen and about 1 sec later the wipers start - this allows at least some water on the screen before the wipers work - however the water does not get to the bottom of the screen so that bit gets wiped dry and I have had to replace one screen because of deep scratches in that area.
micalee Member Since: 24 Apr 2014 Location: Warwickshire s Posts: 241 ![]() ![]() ![]() |
Indeed. I will have to research on why my wipers do not wipe after skirters as yours does. Cheers |
flydive Member Since: 17 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
I usually do short push of the button, so that I can get enough water on the screen, then wait a bit till the water gets to the bottom, then activate the wipers '08 RRS TDV8 I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil |
Does yours not automatically start wiping having pressed the washer button then? |
Yes they do start automatically, that's why I do short push of the button, short enough not to activate the automatic swipe '08 RRS TDV8
If you are doing 110kph down the road the water just goes up the windscreen not down so the water never gets down the bottom. 07MY RRS TDV6 Arctic Frost Aspen Interior |
Ok. Its just mine dont start at all and don't know why |
I usually do 110 in reverse, so works fine ![]() I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil |
