Home > Technical > Windscreen Washer Jets
garrycol
Australia
I push the button and the water squirts onto the screen and about 1 sec later the wipers start - this allows at least some water on the screen before the wipers work - however the water does not get to the bottom of the screen so that bit gets wiped dry and I have had to replace one screen because of deep scratches in that area.
Your need for misting sprayers would help with this.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #448414 Wed Jan 14 2015 11:33am
micalee
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Indeed. I will have to research on why my wipers do not wipe after skirters as yours does. Cheers
Post #448415 Wed Jan 14 2015 11:37am
flydive
I usually do short push of the button, so that I can get enough water on the screen, then wait a bit till the water gets to the bottom, then activate the wipers '08 RRS TDV8
Post #448420 Wed Jan 14 2015 12:22pm
micalee
Does yours not automatically start wiping having pressed the washer button then?
Post #448421 Wed Jan 14 2015 12:27pm
flydive
Yes they do start automatically, that's why I do short push of the button, short enough not to activate the automatic swipe '08 RRS TDV8
Post #448422 Wed Jan 14 2015 12:36pm
garrycol
Australia
If you are doing 110kph down the road the water just goes up the windscreen not down so the water never gets down the bottom. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #448423 Wed Jan 14 2015 12:42pm
micalee
Ok. Its just mine dont start at all and don't know why
Post #448424 Wed Jan 14 2015 12:43pm
flydive
I usually do 110 in reverse, so works fine Wink '08 RRS TDV8
Post #448435 Wed Jan 14 2015 2:30pm
