Home > Technical > weird stiffness in turning since the cold weather?
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
My steering very odd at the minute
It's sort of heavy and stays heavy on turning. Levels are okay. I had it tested about 6 months back by my mechanic where he tested it with a device that floated balls to give a reading Smile so not sure but a fast search points to a pump? I've it booked to go to a service in 2 weeks so ill have them check but like to be fore armed than caught out with car science by a sales man.
Post #447572 Tue Jan 06 2015 6:47pm
Bodsy
Site Sponsor
I'd check the lower steering column first. Takes about 1/2 hour to change and replacement is about £70istr. The joint starts to seize up after a while. Try wd40 on it first, if it makes it easier, then that's the problem. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #447573 Tue Jan 06 2015 7:03pm
designboy
That's awesome news. I'll go try this - any links to doing this?
Post #447762 Wed Jan 07 2015 10:58pm
http://www.disco3.co.uk/forum/topic56798.h...ring+shaft Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #447770 Wed Jan 07 2015 11:57pm
monty19
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
mines started doing this also, wheres the best place to get this from
Post #447776 Thu Jan 08 2015 3:32am
designboy
I'm impressed! Thanks man. Job the night. Bow down
Post #447834 Thu Jan 08 2015 5:27pm
