![]() | Home > Technical > No Backlight on Speedo needle, |
| theGeMan Member Since: 17 Dec 2014 Location: Sussex Posts: 10
just an update, must be a bad connection / dry joint as it came on for 1/2 the journey today before going out just as i parked up,
| idrabble Member Since: 25 Oct 2013 Location: Brisbane Posts: 61
"expect the fix would be a new instrument cluster."
| Siddharthaoke Member Since: 23 May 2014 Location: United Kingdom Posts: 19
Mine does this too (2010 my hse). When it's cold much more noticable as it flickers on and off. As the car warms up the needle flickers from dim to bright and after about 30 mins its normal and no more flickering. Unsure of the cause. I would have assumed a dry solder would have been off or on not flickering dim and bright in between, but unsure, and odd that it's a lot more noticable when it's cold and less so when it is warm.
Yes seams like the same fault, it's had a quick look by a local independent who are going to look at getting the unit repaired if not its a new cluster from Land Rover,
theGeMan did you manage to get this sorted? |
| p.johnson1981 Member Since: 02 Sep 2021 Location: Derbyshire Posts: 1
Hi did you ever find the problem? Im have the same problem on my Discovery 4 (61 plate) |
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961
This is a very common problem,, flickering speedo or rev counter needles. Cheapest option is to send it off to an outfit called totaltronics,, have a look at their website for more details. This isn't a Diy fix and a dealer would sting you for a new cluster,,, if you are close enough they can remove and fix the cluster while you wait. 2010 RRS, TDV8
