Home > Faults & Fixes > RRS 2008 tailgate problems
Mikels24
My 2008 RRS just came back from the garage after the alternator went and while the car was in, they called to tell me the lower tailgate was not working. We had this problem rectified no more that 6 months ago and now it has happened again? Can this be right!? I have tried everything I can think of and the garage has said it needs a new part ordering which means + labour is not going to be even more so after coughing up 700 for anew alternator + labour today!! Big Cry
Any ideas on how I can release the boot manually? Or electronically ?
Mike
Post #446805 Tue Dec 30 2014 7:49pm
Mikels24
To confirm, neither part of the tailgate is working.
Thank
Mike
Post #446806 Tue Dec 30 2014 7:51pm
riverblanche
Hi M'
what part are thy saying needs replacing ?
If it is the same as you had done before is there no warranty from the first repair.
not heard of both top and bottom not working Exclamation our top hatch did not work when we bought the car, usual suspect it was the switch that needed replacing, did a clean up fix soon after buying it, but needed a new switch in the end, easy job to do if its just that ?
Post #446817 Tue Dec 30 2014 8:55pm
SRE
Spain
Could be something as simple as lowering the tailgate in order to close it, but with your fingers on the upper tailgate release.
I did this on mine, what happened on mine, was you are asking the upper tailgate to open as you have your fingers on the release switch and as soon as the lower tailgate touches the bottom latch, the auto close function tries to function, the result was that neither top not bottom tailgate would open and the bottom tailgate was not fully latched.
http://www.rrsport.co.uk/forum/topic29244.html?highlight=tailgate In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #446861 Wed Dec 31 2014 10:23am
