![]() | Home > General > Many Faults!! |
| dazzerboy Member Since: 18 Sep 2009 Location: staffordshire Posts: 212
yes had the lights up was the alternator and I changed the battery as well |
| V8SC Member Since: 29 Oct 2011 Location: Hampshire Posts: 145
I think the brake light switch is a common fault that has also been known to cause these warnings...a fairly cheap and simple fix I believe. Carl |
| aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243
Have you had the fault codes read ?
| D12TYJ Member Since: 01 Sep 2014 Location: London Posts: 183
Sounds more like the alternators over charging, check the volts on it, could even be a brake light switch.
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657
Have you changed a brake bulb recently? 2x TDV6. SE and HSE. Both returned to sender with issues👀
| All times are GMT |
