| RRSPORT.CO.UK | ||
|  | Home > General > Many Faults!! |
| dazzerboy Member Since: 18 Sep 2009 Location: staffordshire Posts: 212      | yes had the lights up was the alternator and I changed the battery as well   | ||
|  Sun Dec 28 2014 5:10pm |
| V8SC Member Since: 29 Oct 2011 Location: Hampshire Posts: 145    | I think the brake light switch is a common fault that has also been known to cause these warnings...a fairly cheap and simple fix I believe. Carl | ||
|  Sun Dec 28 2014 8:54pm |
| aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243      | Have you had the fault codes read ?
|  Sun Dec 28 2014 11:47pm |
| D12TYJ Member Since: 01 Sep 2014 Location: London Posts: 183      | Sounds more like the alternators over charging, check the volts on it, could even be a brake light switch.
|  Mon Dec 29 2014 1:26am |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657      | Have you changed a brake bulb recently? 2x TDV6. SE and HSE. Both returned to sender with issues👀
|  Mon Dec 29 2014 8:52am |
| Posting Rules
