Home > General > Help looking for a replacement 2.7 TDV6
Nhlboy44
United Kingdom 2008 Range Rover Sport TDV6 HSE Bali Blue
Hi All
My engine blew over the holidays so i will need a replacement engine.
Can anyone recommend a good garage bearing in mind i live in the Essex area
Many thanks
Kev
Post #446548 Sun Dec 28 2014 11:59am
Disco_Mikey
Eurojag Thumbs Up
Post #446549 Sun Dec 28 2014 12:00pm
Nhlboy44
Thanks Mikey for the response
I have seen your recommended on all the disco websites and on this site as well.Its a shame you are so far away from me.
What do you think is an average price for a replacement engine and do they go by mileage and year etc?
I have been reading so many bad reviews on what seem like good websites but i guess anyone can have a brilliant website but not be a genuine company who care about their products.
Thanks in advance for your help
Kind regards
kev
Post #446553 Sun Dec 28 2014 12:26pm
Bodsy
Site Sponsor
Go with the eurojag ones as Mikey said.
How did it fail.....? Is it by any chance the timing belt tensioner that has come away from the oil pump casing? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #446561 Sun Dec 28 2014 2:43pm
Disco_Mikey
I paid £2500 for a 49k engine. They did have cheaper ones available, but with a higher mileage.
I replaced my own engine in 23 hours, though this included a few extras, such as suspension arms, brake pipes, silicone hoses, gearbox oil.and filter etc. And that was flat out over 2 days wirh no breaks, as I only had the ramp for those 2 days
Post #446574 Sun Dec 28 2014 4:28pm
Nhlboy44
not sure yet as my mechanic will come over tomorrow to strip it down.I had a new belt and tension fitted only 600 miles ago but there was a low tone noise coming from engine and Lookers land rover suspected timing chain or valves but they were not 100%.
It would of cost me at least £1300 min for them to fault find and then that could of risen as they were not going to gaurentee it would end there.Plus that was only to strip to middle engine if more extensive striping the meter was running as they say.
So i could of had a bill of over £2K and then still not fixed the problem so i thought would take my chances as i knew rough price for recon or second hand engine would be around £2500.
Once i know what the reason for failure was ill post the result.
The car has only done 68000 miles from new and its an 08 with full history and only 2 owners.
Post #446595 Sun Dec 28 2014 7:18pm
Nhlboy44
Thanks Mikey once my guy has had a look ill post the result.I will give Eurojag a call in the morning
thanks again for your advice
Post #446596 Sun Dec 28 2014 7:21pm
Disco_Mikey
If it is the oil pump, it will take around 45 mins to strip and check. Failing that, I have seen a few 08s with broken con rods and crankshafts
If this is the case, it would be worth getting in touch with the LR rep on the forum before stripping the car too far. Bottom end issues are not unknown inside of LR, and they released an "improved customer handling experience" for these known issues.
Edit: does the car still run at all, or is the bottom end seized?
Post #446597 Sun Dec 28 2014 7:27pm
Nhlboy44
Thanks Mikey i will advise him tomorrow
The car has stopped running there were w couple of clanks then died ?
If it is bottom end are you saying LR help out with repair cost?
Post #446598 Sun Dec 28 2014 7:31pm
Disco_Mikey
Copy of the SSM:
Quote:
Reference SSM71816
Models
Discovery 4 / L319
Discovery 3 / L319
Range Rover / L405
Range Rover Sport / L494
Range Rover Sport / L320
Title Crankshaft/Crankshaft Bearing Concerns - TDv6 Diesel Engine
Category Engine
Last modified 06-May-2014 00:00:00
Symptom 499000 Basic Engine
Content
Issue:
Crankshaft/crankshaft bearing failure - TDv6 Diesel Engine.
Cause:
Low incidence of crankshaft failure are being encountered, caused mainly by incorrect location of the main bearing shells during assembly, or through rotation of the shells during normal use. A new procedure has been implemented to ensure:
- more rapid resolution of customer concerns, and
- greater visibility of failure modes in order to improve repair process and parts delivery.
Action:
For any suspected crankshaft/bearing failure, please contact your local Dealer Technical Supportor FRED team for details of the enhanced customer handling procedure.
The list below summarises typical symptoms of crankshaft/bearing failure, but please contact your DTS/FRED team if in any doubt as they will be pleased to offer assistance:
· Crankshaft is seized, engine cannot be turned either via starter motor or crankshaft pulley bolt.
· Oil sump or engine cylinder block is holed, with oil leakage and/or metallic debris found on engine under-tray.
· Engine makes a loud ‘rumbling/knocking’ sound when running which worsens as the engine is placed under load. The engine oil pressure warning light may flash or be continuously illuminated, especially at low engine speeds.
Some members of the D3 forum have had engines replaced fully FOC. If you don't ask... Whistle
Post #446603 Sun Dec 28 2014 7:44pm
Michael7s
England 2010 Range Rover Sport TDV8 HSE Santorini Black
I'm wondering why LR dealers don't sell engine parts (piston rings etc) to fix the engine.
Rather than spending £200 for few parts I have to get 2nd hand one (3.6 tdv8) :/
Post #446616 Mon Dec 29 2014 12:36am
Bodsy
Site Sponsor
If you have full service history, then this type of issues should be pushed back to LR to resolve. Especially at the mileage you have. Did LR do the timing belt?
I had the 'other' issue with the 07/08 engines and even on 101,000 part LR, Part Indi service and even though the car was 5 years old, they replaced the engine FOC.
It's all about the facts presented and the words/determination you have. Thumbs Up Bodsys Brake Bible
See it HERE
Post #446618 Mon Dec 29 2014 12:47am
Nhlboy44
Hi There
It was an Indi LR garage that replaced the belt at my request.They said the low tone noise coming from engine In their opinion was crank shaft but they was not sure.They did say that there had been major issues with 2.7 cranks and added you cannot buy replacements.
I took my chances and now have a major failure.
I have had advice from MMP and my fitter will take timing belt off and see if the problem is there if not and it is crank then i will try to contact LR but i do not know to address letters to.
If you have any contact names and address that would be great.
Thanks for your input
Many thanks
Kevan
Post #446700 Mon Dec 29 2014 8:38pm
Nhlboy44
I agree if it is a problem why don't they sell replacement part like all other manufacturers ??
Post #446702 Mon Dec 29 2014 8:41pm
Disco_Mikey
Bodsy is your man. He has been there and done that. A PM to him would be well worthwhile Thumbs Up
Post #446707 Mon Dec 29 2014 8:59pm
