Home > General > Help looking for a replacement 2.7 TDV6
simple1
Worth talkng LR rep. I got a huge settlement contribution from LR after a fight. If you want some contact/pointer info PM me as I am forbidden to reveal details on open channel Rolling with laughter 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #446724 Tue Dec 30 2014 7:03am
Nhlboy44
United Kingdom 2008 Range Rover Sport TDV6 HSE Bali Blue
Disco_Mikey wrote:
If it is the oil pump, it will take around 45 mins to strip and check. Failing that, I have seen a few 08s with broken con rods and crankshafts
If this is the case, it would be worth getting in touch with the LR rep on the forum before stripping the car too far. Bottom end issues are not unknown inside of LR, and they released an "improved customer handling experience" for these known issues.
Edit: does the car still run at all, or is the bottom end seized?
Hi Mikey
Well here is another twist when my guy came over today the engine is turning over ???
He wasn't sure what to do now so is going to try speak to a friend who has worked on rr
Any ideas ?
Post #447220 Fri Jan 02 2015 10:44pm
Disco_Mikey
Had the same with my own car. When the engine was hot, everything seized up. When it was cold, it would turn over fine, and given enough persuasion, it would run...
Post #447221 Fri Jan 02 2015 10:47pm
Nhlboy44
And what was the problem?
Post #447230 Sat Jan 03 2015 7:26am
Disco_Mikey
Oil filter fitted wrong, causing the oil flow through the engine to be affected, and piston started overheating and melting...
Post #447233 Sat Jan 03 2015 8:37am
Nhlboy44
Ok
Lee,my mechanic , he said engine turns over then locks. leave it a bit then try again and same it turns over couple of times then locks.
He said he is going to remove sump to see if its crank or if there there are any clues in sump casing.
He has asked for your number so i have seen it on your site maybe he might try to call you for advice.
He is a serious land rover series One owner and and been a mechanic for over 35 years but has never had to do any repairs on a RRS or D 3
Hope its ok to pass your number
regards
kevan
Post #447399 Sun Jan 04 2015 5:34pm
Nhlboy44
hi Mikey
At last euro-jag have a engine for me,68K, i have decided to take it to an indy garage near me as they seem to be on the ball.
They are all x land rover employes and have quoted a fair price.
They warranted all their work but of coarse they cannot warranted the engine.
Ill let you know how it all goes im missing my RRS as been off the road now since boxing day.
Kev
Post #450737 Sun Feb 01 2015 3:12pm
ACE 219
Did you dismantle your engine to see what the fault was?
Post #450772 Sun Feb 01 2015 5:41pm
Nhlboy44
Not yet but my mechanic took sump off
And he said Crank failure as alloy and brass bits
In sump.
And judging by the noise it made it will be the crank
I'm So upset with LR as they will not look at unless I pay the engine strip charges
Which I cannot afford
So have cut my losses and put a replacement in
Kb
Post #450813 Sun Feb 01 2015 8:41pm
Disco_Mikey
Sounds familiar...
Post #450819 Sun Feb 01 2015 9:08pm
