Home > General > Bulb question ??
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Bulb question ??
hi again, ok so we have high and low beam, side lights, fog lights but.... how and what are the two halogen bulbs for next to the side light bulbs for, and how do you turn them on, and... what are they for ???? they do not come on with high beam or low beam or front fogs ?? please educate me. Thumbs Up
Post #442738 Sun Nov 16 2014 7:41pm
Those are the fixed bending lights - they should illuminate when you turn at low speed. Depending on your specification, they come on when you tun the steering wheel and / or when you indicate. They only work at low speeds. 2012 SDV6 - it's missing a couple of cylinders
Post #442740 Sun Nov 16 2014 7:45pm
Gornal Hills
thanks for the prompt reply, its an 07 HSE, I saw them on the other night and was confused as to what they were, thanks again Thumbs Up
Post #442742 Sun Nov 16 2014 7:50pm
Andi
Looks quite good, not too sure how necessary it is! Both my bulbs just blown within a month or so of each other. Dan @ Duckworths to the rescue again with a great price. Thumbs Up
Post #442744 Sun Nov 16 2014 8:01pm
They're one of those options that you think "er, why?" when you first have it. Then you drive a car without them and you think "oh, I wish I had the cornering lights on this!" Rolling with laughter
I find them to be a useful thing. I keep thinking of replacing the bulbs with an LED equivalent to get a cleaner light (mine are quite yellow and not that bright now). 2012 SDV6 - it's missing a couple of cylinders
Post #442764 Sun Nov 16 2014 9:46pm
Andi
Yes, I'm sure you are right, I will probably miss them when they are gone. Laughing
Post #442769 Sun Nov 16 2014 9:56pm
Gornal Hills
So can you see them going on and off and when does this actually take place ?? Confused
Post #442841 Mon Nov 17 2014 5:56pm
Andi
Yep. Stop facing a wall, put in drive, turn steering wheel left or right and look for extra lighting come on and then fade away.
Post #442843 Mon Nov 17 2014 5:59pm
Gornal Hills
Was these an optional extra or fitted as standard, mine has the fridge in the center console was this also standard, and a sunroof , loads of questions Thumbs Up
Post #442847 Mon Nov 17 2014 6:13pm
simple1
Depends what year yours was and if it's a V8. Roof was an option but in 2007-8 the fridge, responsive cruise and logic7 were standard items in HSE which was the only V8 model. They also came with front and rear parking sensors, active lights and turning lights. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #442914 Tue Nov 18 2014 3:20pm
Not sure Logic7 was standard on the TDV8. Mine is just the HK system I think. 2012 SDV6 - it's missing a couple of cylinders
Post #442921 Tue Nov 18 2014 4:14pm
simple1
Might have ticked that box then. Think you had to have logic 7 to go with rear screens which I had. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #442941 Tue Nov 18 2014 6:39pm
