![]() | Home > General > Bulb question ?? |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
hi again, ok so we have high and low beam, side lights, fog lights but.... how and what are the two halogen bulbs for next to the side light bulbs for, and how do you turn them on, and... what are they for ???? they do not come on with high beam or low beam or front fogs ?? please educate me. |
thanks for the prompt reply, its an 07 HSE, I saw them on the other night and was confused as to what they were, thanks again |
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 ![]() ![]() |
Looks quite good, not too sure how necessary it is! Both my bulbs just blown within a month or so of each other. Dan @ Duckworths to the rescue again with a great price. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
They're one of those options that you think "er, why?" when you first have it. Then you drive a car without them and you think "oh, I wish I had the cornering lights on this!" |
Yes, I'm sure you are right, I will probably miss them when they are gone. |
So can you see them going on and off and when does this actually take place ?? |
Yep. Stop facing a wall, put in drive, turn steering wheel left or right and look for extra lighting come on and then fade away. |
Was these an optional extra or fitted as standard, mine has the fridge in the center console was this also standard, and a sunroof , loads of questions |
Not sure Logic7 was standard on the TDV8. Mine is just the HK system I think. 2012 SDV6 - it's missing a couple of cylinders
Might have ticked that box then. Think you had to have logic 7 to go with rear screens which I had. 2x TDV6. SE and HSE. Both returned to sender with issues👀
